hard core 1970 front sus. options
What is avaible in complete front suspension for a 1970 mach 1? Cross member, both control arms, spindles, rack & pinon, coil overs. Weld in OK!
Would like to eliminate most of the spring towers.
you got this http://www.martzchassis.net/page3.htm or http://www.rrs-online.com/index.php front coil overs but you can only notch the shock towers
if you can afford it look into Total Control Products- http://www.totalcontrolproducts.com/. I have their upper and lower control arms, strut rods, and rack and pinion. I highly recommend their products.
If you want a setup that works and is not stupid-expensive you might try.....
http://www.maierracing.com/
They do not sell anything that will hep you eliminate the spring towers, if you want to do that you would probably have to go Mustang II, but...... I think that may be more trouble than its worth unless you want to make it some sort of air ride show car. Check out Muscle Car on Spike TV, they have a mustang that they have chopped up and put a Mustang II front end under.
http://www.spiketv.com/#shows/muscle...n=episodeGuide
