Need a little help.
Old Feb 7, 2007 | 08:42 PM
Red Coupe's Avatar
Red Coupe
Default Need a little help.
How much vac pressure should I expect from the carb to the vac advance?
I've got 21 ft/lbs at the manifold but nothing at the vac port on the side of the carburetor that feeds the vac advance at the distributor.
This is a new carb. Do I need to take it off a blow out the vac port? Any suggestions as to why I would loose vac pressure at the carb?
Old Feb 7, 2007 | 09:09 PM
ponyx2's Avatar
ponyx2
Default RE: Need a little help.
Any vacuum at part throttle on that port?
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
NYstang
Sep 30, 2015 09:56 PM
mustangheaven
Sep 29, 2015 11:00 AM
