piston rings?
Old Feb 8, 2007 | 03:40 AM
Sean W.'s Avatar
Sean W.
Default piston rings?
can you buy JUST piston rings? my pistons are in perfect condition, i just need piston rings, but i cant find where i can buy, just piston rings, its for my 5.0L/302.
Old Feb 8, 2007 | 03:43 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: piston rings?
ya you can just buy the rings if you do get the gapless ones those are friggin sweet i am gunna use them on my next build
Old Feb 8, 2007 | 11:54 AM
coda618's Avatar
coda618
Yes you can get just the rings. Try Summit, PAW, Jegsetc. Also look on ebay, i see them there all the time. Just make sure your pistons are stock, or whatever sized so you get the correct rings.
Old Feb 8, 2007 | 01:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
You can get a set of mollies on Ebay for 40 bux right now.
http://cgi.ebay.com/ebaymotors/Moly-...QQcmdZViewItem
Old Feb 8, 2007 | 01:51 PM
my77stang's Avatar
my77stang
90% of the time your pistons will be fine. the question is what do the cylinder walls look like? if you can catch your fingernail on the ridge at the top you should be getting it bored if you want the motor to last. if you dont have the budget or just dont care - at LEAST get a ridge reamer (free tool rental from local auto parts) and take that ridge off the top..... i cannot stress this enough to BEEEEEEEEEE CAREFULLLLLLLLLLLL when using that tool, do NOT take too much out. then use a 3 stone hone with very fine grit if your using moly rings, and hone the cylinders (another free tool rental). now, if you have access to one, finish with a fine grit dingle ball hone, they leave a better cross hatch than the 3 stone jobby
poke68
Dec 16, 2025 03:36 PM
uberstang1
Dec 7, 2017 07:10 AM
Dathan
Oct 5, 2015 05:52 AM
DJ Piner
Sep 30, 2015 03:03 PM
degner122
Sep 16, 2015 07:09 AM
