Testing Fan Clutch
Old Feb 8, 2007 | 01:11 PM
Toddman0025's Avatar
Toddman0025
Default Testing Fan Clutch
Is there a correct way to determine if a fan clutch needs to be replaced? See if it continues spinning when the motor is shut off?
Old Feb 8, 2007 | 01:39 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
Default RE: Testing Fan Clutch
Start the car and heat it up to normal temperature. Then turn the car off. Spin the fan and if it travels more that 1 1/2 revolutions the clutch is probably worn out and needs replaced.
my77stang's Avatar
my77stang
you could stick your hand in there while the cars running..... if you loose your digits it works[8D]
Old Feb 8, 2007 | 01:41 PM
Toddman0025
ORIGINAL: my77stang
lol
my fan seems to spin constantly, not sure what normal behavior for a thermal clutch is...
Old Feb 8, 2007 | 01:42 PM
grruminator78's Avatar
grruminator78
[sm=vader.gif]
ORIGINAL: my77stang
[sm=signs003.gif]
Old Feb 8, 2007 | 01:44 PM
my77stang's Avatar
my77stang
a clutch fan WILL always spin, but when its not fully engauged its not dragging HP away from the motor so bad, its kinda just flappin in the breeze
Old Feb 8, 2007 | 02:39 PM
OhioMachIRunner69
Is the car overheating when it is sitting still? If not then your clutch fan is probably ok. If the car overheats sitting still and then you drive the car at a constant speed and the temp falls to normal levels the clutch is probably bad.
I do not believe that the the 351C should have a clutch fan at all actually. If it is the same as the 351W the correct fan is a 5 blade fan with no clutch. I do not have my book in front of me with part numbers. Maybe someone else can chime in?
Old Feb 8, 2007 | 02:50 PM
UBY289's Avatar
UBY289
I played around with mine on my 67 289 and couldn't figure it out,so I got a new one and it made a big difference in the cooling .It was will worth the $35 .
BOB ROME
Jul 26, 2023 01:54 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
