stroker engine issues
Old Feb 9, 2007 | 06:18 PM
supraman408's Avatar
supraman408
Default stroker engine issues
do stroker engines have longivity problems and are prone to oil burning issues? can you get more miles out of a 302 rather than a stroker?
would i need a new tranny and rear end with the 347? or is a rebuilt tranny and 8in rear end adequate?
(planning on getting a 347 and using it as a weekend/monthly driver, i dont think i will be pushing it too hard too often)
Old Feb 9, 2007 | 06:23 PM
grruminator78's Avatar
grruminator78
Default RE: stroker engine issues
short answer, not so much anymore. I believe most engine builders took care of the major oil issues in 347 strokers, if it still bothers you just get a 331.
eZ's Avatar
eZ
unless you are going to be using the car as a daily driver dont worry about the longevity of the motor. it all depends on how much horse you try to squeeze out of that 302 or 347. you can build a 302 to put down 350-400 pretty easy.
[/align]
Old Feb 9, 2007 | 10:24 PM
my77stang's Avatar
my77stang
just make sure your using quality pistons. i know some of the 351w / 427 stroker pistons had the oil ring intersecting the wrist pin hole and they used some oil.
Old Feb 9, 2007 | 11:33 PM
mustanglover66's Avatar
mustanglover66
As long as it is built by a quality shop it will last, what kind of trans do you plan on running will determine if it will last. as for the 8' rear I blow mine with a worn out 302 so I don't have much faith in them, but others on here will swear by them so use your own judgement there.
Old Feb 10, 2007 | 12:27 AM
my77stang's Avatar
my77stang
i havent touched mine yet, only changed the fluid in there. its an 8" with 3.40's - i think i have some axle bearings loose though, i can actually move the tire up and down a bit when its jacked up. oh well, run it till it blows then stuff a 9" under there
Old Feb 10, 2007 | 03:24 AM
andrewmp6's Avatar
andrewmp6
one of my friends had ran a 350 chevy stroked to a 427 for 3 years now daily driver no problems like they said good parts are the key
djbigskrilla
Sep 20, 2022 01:04 AM
P51_GT
ROUSH Performance
24
Apr 6, 2019 09:19 PM
drfister
May 3, 2018 10:38 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
mweiland
Aug 13, 2015 05:11 PM
