How To Get Into The Window Assembly
Old Feb 16, 2007 | 10:44 PM
SUPERSTEVE9219's Avatar
SUPERSTEVE9219
Default How To Get Into The Window Assembly
How do I get into the window assembly? The post that sticks out on the for the winodw roller handle was striped but I had to buy half of the window track and other stuff but how do I get into the door so I can replace what I need?
Sorry I dont know the proper term for everything.
BTW: I have a 1968 coupe
Old Feb 16, 2007 | 11:30 PM
hity645's Avatar
hity645
Default RE: How To Get Into The Window Assembly
You could do it how my dad did it, dis assemble everything inside the door pull it all out and risk damage, or buy the door tool and then weld (i think???) back together. That would be the easistest and best choice, when it comes time to redo my doors I'm going to purchase this tool to avoid damaging the window.
Old Feb 17, 2007 | 01:04 AM
JamesW's Avatar
JamesW
Is your question how do you get into the door to get to the window assembly mechanism? Take the interior door panel off. Then reach through the holes in the door shell to get to the pieces. Everything comes out through the openings. This below is for a 65 but yours will be similar.
Old Feb 17, 2007 | 02:21 AM
SUPERSTEVE9219
dam seems like it would be hard to all that and just fit it through those holes, O well I will try agian tommrow and if I cant get it ill post some pics of how it is on my car
Old Feb 17, 2007 | 02:28 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
nah it will go in failry easy its a 60's car
Old Feb 17, 2007 | 01:54 PM
restomod66's Avatar
restomod66
James,
Nice door illustration!!!! That should make the job a little easier to understand.
Old Feb 17, 2007 | 07:24 PM
676869Stangs's Avatar
676869Stangs
Just finished removing the entire drivers side window, including vent. Not all that difficult, the hard part was putting it all back in and getting the alignment right.
T
Old Feb 17, 2007 | 08:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think we kinda skipped over the initial question. To get the door panel off, you have to use a phillips screwdriver to take off the arm rest. Then, using an Allen wrench, you take off the door handle and window crank. After those are removed, you use something wide and thin like a wide putty knife to carefully pry the outside edges of the door panel off. Once you get the door panel off, then refer back to James' illustration.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mungodrums
Sep 22, 2015 08:36 PM
