gettin pissed off
Old Feb 18, 2007 | 07:59 PM
j code kid's Avatar
j code kid
Default RE: gettin pissed off
sounds like like your radius rod bushings are worn out .( just underneath bottom of radiator sits ) .need replacing or if stiil good tighting that big 1 1/8 nut ,,, my dads little 1989 mitsubishi COLT used to do that also ,,,i took it out and thrashed the helll out of it and when you hit a bump or brakes it would pull left severly changed the perished radius rubbers ,,beutiffullllllllllllllllllllllllllllllllllllll
Old Feb 18, 2007 | 10:26 PM
Aussie66Fastback's Avatar
Aussie66Fastback
check your ball joints too
i just did the bottom ones...that dont take as much load as the top
the play was enough to make the car feel unstable and wander about abit on the bumps
also toe-in settings can make it feel like it is "tram tracking" with any deviations in the road surface.
this might sound nuts, but one member here found most of his problems solved when he put an engine cross member in the car...it didnt have one!!!!
good luck.
Gun Jam
Oct 4, 2015 12:10 AM
Takeiteasee
Aug 27, 2015 03:59 PM
svtrosey
SVT Forums
Aug 15, 2015 09:09 PM
