dyno hp
Old Feb 18, 2007 | 02:57 PM
stallions's Avatar
stallions
Default dyno hp
can anyone tell me how much horsepower loss there might be from the engine to the rear wheels? I have a 65 289 hipo it dynoed at 258 at rear wheels. Just wondering what I might have at the engine. Was told 100 horsepower loss, through the drive train that sounds low to me, it is a 4 speed.
thanks
Old Feb 18, 2007 | 03:24 PM
gothand's Avatar
gothand
Default RE: dyno hp
I always thought that arule of thumb forthe difference was closer to 50hp for a manual and 75 hp for an auto.
Old Feb 18, 2007 | 05:47 PM
65mojoe's Avatar
65mojoe
Default RE: dyno hp
the rule of thumb is usually a 15-20% hp loss through the drivetrain. So, if you dynoed 258rwhp, you're losing about 38-48hp from the transfer...which means at the flywheel you're probably seeing ~290-300hp.
Old Feb 18, 2007 | 05:54 PM
ih8chevy's Avatar
ih8chevy
Default RE: dyno hp
its a simple equation, ur loss through a manual is about 15 percent. so
u take the 258 u made, multiply that by 1.15 cause u want the extra 15 percent u lost, and then u will have ur number. i did and got 296.7 hp at the flywheel.
Old Feb 18, 2007 | 06:56 PM
mikethebike's Avatar
mikethebike
Default RE: dyno hp
If you are using an 8 or 9 inn Ford differential that alone uses about 7% of your gross hp. That would put you at around 275-280 not including transmission loss. Not too shabby for a 271/289. Bet you aren't running a factory cam...maybe a Crane Fireball? What about headers?
Old Feb 18, 2007 | 07:02 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default RE: dyno hp
does my factory AC unit drain HP too? I could go without it ...
Old Feb 18, 2007 | 07:05 PM
my77stang's Avatar
my77stang
Default RE: dyno hp
not while its not running it doesnt.... while off its just turning the pulley which is like less than 1 hp if i had to guess
Old Feb 22, 2007 | 07:31 PM
stallions's Avatar
stallions
Default RE: dyno hp
very good 'comp cam try y headers world products Windsor jrheads roller rockers
Galactic
Apr 29, 2019 02:56 PM
articman
Jun 21, 2018 11:45 PM
heslekrants
Sep 23, 2015 04:02 PM
The01Cav
North East
Sep 5, 2015 03:39 PM
The01Cav
Maryland Regional Chapter
Aug 31, 2015 04:12 PM
