Tremec 5 Speed in Classic
Has anyone put a late model Tremec transmission into a classic Mustang? If so, did you encounter any issues that I should consider before doing this?
I am about to move forward with this, and I am fairly sure that this should be fairly straight forward, but I thought I better check around first.
Thanks in advance for your help!!
RE: Tremec 5 Speed in Classic
maybe this will help a little: http://www.fordmuscle.com/archives/2000/09/t5swap/
You will need to make a mount. Really easy. Or you can buy one for about $130.I have done 2 and gearing up for the third. Whats the final drive? Shifter will be close to the right side of the opening in the tunnel. I just mount a Hurst handle on the left side of the stub and after the boot is on, you can't tell it.
www.mustangsteve.com has a pedal kit that uses the late model cable its cool esp if ur car has a auto now and need pedals
ORIGINAL: 67 evil eleanor
The final drive is a 4.10,
And thanks for the input!
ORIGINAL: 2bav8
I put a Tremec in my '66 about 9 years ago.
Install was easy and benefits have been impressive.
Thanks for the input!!
