alighnment help
Old Feb 21, 2007 | 11:09 AM
quailwhite's Avatar
quailwhite
Default alighnment help
help front springs was told my 68 was adjusted all the way they could not align said i need new spring before they could align ,have youever heard of this or do i need to go else where for alignment please help
Old Feb 21, 2007 | 11:14 AM
ZZmustang's Avatar
ZZmustang
Banned
Default RE: alighnment help
Soft springs will effect alignment, But they could align it with soft springs, If you got new spring then you would have to align it again. They wanted to sell you springs.
If your springs are softor sagging get new ones first then align it.
Old Feb 21, 2007 | 11:34 AM
THUMPIN455's Avatar
THUMPIN455
adjusted all the way? Did they mention the dimension they have to the limit? It could only be camber since you have an eccentric on the lower control arm for adjustment. Caster and toe have a large range on the tie rod ends and strut rods to make adjustments.
Is your car lowered or raised up pretty high? Very low without the shelby drop will cause that and other things, too high like a 4x4 or gasser will also reach the limit. If its lowered the Shelby drop should help..
Do you have the factory springs still in it?
mn102483
Suspension
Mar 5, 2013 11:33 PM
n2spd
Sep 11, 2007 08:28 PM
MustangKid89
Apr 26, 2007 12:36 AM
06burggt
Jan 12, 2007 01:44 PM
MustangChris04
18
Apr 23, 2006 06:02 AM
