Shifter upgrade
Old Feb 23, 2007 | 02:36 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
Default RE: Shifter upgrade
this is the **** im looking at.... is it gooooood?
http://www.fastpts.com/cgi-bin/hazel...mshifters.html
B&M 80842 PRO RATCHET RACE SHIFTER
Old Feb 24, 2007 | 05:10 PM
65mojoe's Avatar
65mojoe
ORIGINAL: NuclearMuscle523
Ok quick explanation about gate shifters versus ratchet shifters.
An aftermarket gate shifter shifts similar to a a standard automatic shifter: when you shift from one gear up into another: 1) the stick moves forward into the the next gear and 2) you hear (and feel) a positive click of the shifter mechanism passing into the next gate of the shift sequence. Often times to go from 1 to 2, all you have to do is slam the thing into the next gear, but to go from 2 to 3 (or D) you have to squeeze the trigger on the stick in order to disengage the small lockout pin that keeps the shifter from slipping out of the second gear gate and going into 3rd (or worse.....Neutral or Reverse!)
Now a ratchet shifter works a little differently. The stick on a ratchet, while in gear while always remain stationary, and then when you're ready to shift, you push the stick forward. You will hear a "ratcheting" noise, and on the shift indicator, you will see the gears change from 1 to 2, and 2 to 3, and so on. A ratchet is great for making quick up or down shifts, all the while keeping the stick in the same position. Ratchets can be abused pretty hard and they provide a positive up/dowshift "ratchet" noise, but they can be a little more physically demanding than gate shifters.
Now the one you're lookin at is NOT a ratchet, its a gate shifter Yes thats a nice one, its kind of ugly though.
Old Feb 24, 2007 | 05:18 PM
Yonco's Avatar
Yonco
i Have a B&M megashifter and its nice, gets the job done with ratcheting for quick shifts, just a little wierd to get used to. -Jon
Old Feb 24, 2007 | 05:25 PM
65mojoe's Avatar
65mojoe
The one negative thing to ratchet shifters is that it can be very easy to lose track of what gear your in because the stick stays in a stationary position. In a race situation or even in normal driving, it can be a bit dangerous if you have to look down for a second to check the indicator and see what gear you are in. That's why I prefer gate shifters because along with the same positive "click" that you get from a ratchet, you also get the movement in between gears along with it.
I also forgot to mention that on both ratchet and gate shifters, most all have a reverse lockout system, which is the little red lever at the front of the shifter body. In order to get into reverse (and also park) you have to engage this switch forward and then shift into reverse or park.
Old Feb 25, 2007 | 12:21 PM
NuclearMuscle523
okay.... i bought the pro ratchet..... is it easy to install or do i have to remove the transmission?
Old Feb 25, 2007 | 05:10 PM
65mojoe's Avatar
65mojoe
The shifter comes with the cable and the necessary brackets to install it. No, you don't need to remove the tranny. From the sounds of things, I would have a professional install it and adjust it for you. It took me several times to adjust the cable so that it shifted correctly according to what gear the indicator said it was supposed to be in.
Old Feb 26, 2007 | 12:07 PM
NuclearMuscle523
how much would a professional cost?
Old Feb 26, 2007 | 02:26 PM
65mojoe's Avatar
65mojoe
maybe an hour or so worth of labor charges for installation and fine tuning the cable adjustment
Old Feb 26, 2007 | 03:21 PM
Gun Jam's Avatar
Gun Jam
I also have the pro ratchet It awesome the next best thing would be a 5 speed or 6 speed manual.
you should be happy with it
Gun
Old Feb 27, 2007 | 06:19 PM
NuclearMuscle523
so $70 worth of labor.... gay..... i bought the thing for $170
PaulH2
20
Jan 31, 2016 09:48 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
