Distributor and timing chain removal
Old Feb 24, 2007 | 01:45 PM
white69mach1's Avatar
white69mach1
Default Distributor and timing chain removal
ok some people probly are going to laugh but i have my motor pretty muched strip down and i have no clue how to get the distributor off people keep telling me there are some bolts where at because i dont see any and how to get the timing chain off.this is on a 1969 351w
Old Feb 24, 2007 | 01:53 PM
mustanglover66's Avatar
mustanglover66
Default RE: Distributor and timing chain removal
bring the motor to TDC on the number one cylinder. remove the bolt anc hold down under the distributor. after that it should pull out. as for the timing chain remove the bolts holding the gear on and pull the gear off.
Old Feb 24, 2007 | 02:02 PM
white69mach1
the motor is being redone with all new parts so im not worried about tdc where is the bolt for the distributor
Old Feb 24, 2007 | 02:36 PM
mustanglover66
the distributor will not come out unless the motor is at TDC and the bolt is right under the dist. nolding the shaft in.
[IMG]local://upfiles/33399/4C2F8300129545FC88E202C47C770144.jpg[/IMG]
Old Feb 24, 2007 | 06:22 PM
white69mach1
thanks
Old Feb 24, 2007 | 06:35 PM
gothand's Avatar
gothand
ORIGINAL: mustanglover66
Are you sure about that? I'm almost positive that the distributor can be put in or taken out in any position, ergo, you can get a distributor mistimed.
Old Feb 24, 2007 | 06:50 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: gothand
+1 it will come out anywhere u try to pull it from. the bolt is 1/2"
for the timing chain removal ull need a pluuer they loan them at autozone(just have to leave a deposit) ull need to remove the harmonic balancer,waterpump,timing cover,on the cover is off the timing set will be exposed theres a bolt holding the fuel pump ecentric on remove it then pull the gears from the motor
Old Feb 24, 2007 | 07:28 PM
white69mach1
where is the bolt at for the distributor i dont see one and i already have everything off but the timing chain and distributor
Old Feb 24, 2007 | 08:42 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
look where the dist come out of the motor there should be one boltstowards the front of the motor that has a hold down under the bolt remove it and pull it out
Old Feb 25, 2007 | 03:31 AM
Colorado_Mustang's Avatar
Colorado_Mustang
The dizzy can be removed when the engine is any direction. Sometimes, the oil pump shaft will have jammed in the bottom, making it very difficult to remove. This is also another reason to use a good aftermarket oil pump shaft...
Granatelli Sales
Jan 20, 2020 12:34 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
CarrieS
Sep 1, 2015 01:00 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
