Upper Control Arm
Old Feb 26, 2007 | 04:50 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default Upper Control Arm
i am wondering if i should replace or rebuild my upper control arms
Old Feb 26, 2007 | 05:11 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Upper Control Arm
Well the shaft kits are like $10 cheaper than the full arms, then there is the ball joint.. I have nice uppers and the bushings arent bad either, still they are getting replaced.. its good to have spares at the stage Im at with it..lol..
Find out how much difference there is cost wise doing it both ways, then decide if the work is something you want to do.
Old Feb 26, 2007 | 05:13 PM
gothand's Avatar
gothand
Whichever way you go, make sure you end up with zerks on the upper joint so you can grease them.
Old Feb 26, 2007 | 06:25 PM
arthur's Avatar
arthur
i was considering rebuilding them too .. but when putting all the cost of the rebuild kits , the work , i decided it is more economical to get new ones, beside that they have made the new ones better compared to the originals ( atleast those i will go for)
arthur
Old Feb 26, 2007 | 07:04 PM
latamud's Avatar
latamud
If you are going stock repop replacement you are better off rebuilding your old ones. There isn't much to rebuilding these old arms. You would probably only need new grease seals for the shaft end caps, recommend greasable end caps if you don't already have them, and moog ball joints. I rebuild mine. I add 12degrees offset on the balljoint angle, then do the shelby drop but 1 3/4" lower than stock. The stock arm is stronger than the repop stuff. Otherwise, I'd opt for Opentracker, Global West, or Total Control arms.
Old Feb 26, 2007 | 07:18 PM
Brandontyler65
I ♥ Acer
well i got moog shaft and ball joints all together for $50 i was just wondering if i should replace the shell cause i am gunna do the shelby mod and 620lb/in springs but its just DD and the occasional hard corner but thats about it
Old Feb 26, 2007 | 07:23 PM
andrewmp6's Avatar
andrewmp6
im lazy i just replaced mine and i dont trust a 40 year old stamped seal one
Old Feb 26, 2007 | 07:31 PM
Brandontyler65
I ♥ Acer
i have heard that the stockers were stount and even much more so than the chinese steel repros of today
Old Feb 26, 2007 | 08:34 PM
latamud's Avatar
latamud
I don't know where i saw it but someone had a problem with a repop arm. They are not stamed to the exact same dimensions. Well, basically everything will blt up the same, shaft, balljoint perch are all in their proper locations but... the stamping shape mear the mounting surface was not accurate.
At these points, the "Chinese" not having a classic Mustang to test fit to make sure tolerances were good left a little bit more material there. This causes a bind at some points of motion between the arm and the shock tower. This bind causes the shaft to tear the arm apart. I cant find the pic online but imagine the shaft still bolted to the shoct tower but the arm not, or the hole that the shaft runs through pulled so hard that it looks like a hook. If I can find it I'll post it.
Old Feb 26, 2007 | 09:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: latamud
It's called a hack saw and an emery wheel to get them right after they come out of the Chinese factory. I would opt to rebuild the originals, and certainly have grease zerks in them. I grease my joint occasionally.
