BODY WORK QUESTON
Old Feb 28, 2007 | 12:18 PM
white69mach1's Avatar
white69mach1
Default BODY WORK QUESTON
i was just wondering what people here have spent on body work
Old Feb 28, 2007 | 12:20 PM
Grimm's Avatar
Grimm
Default RE: BODY WORK QUESTON
Doing it myself right now. Estimate I'll spend about $1,500.00 in sheet metal. That doesn't include labor.
Old Feb 28, 2007 | 01:14 PM
scott_m_mil's Avatar
scott_m_mil
yeah, but Grimm the only thing your car had left was the steering column
Old Feb 28, 2007 | 03:23 PM
Grimm's Avatar
Grimm
Yeah and?
Old Feb 28, 2007 | 04:23 PM
THUMPIN455's Avatar
THUMPIN455
Well so far its $3000 for sheetmetal on the Mustang, and for the Cougar around $1800 for primer, sealer, filler, and all the stuff needed to work that like air sanders, sandpaper, hoses, and misc stuff. The compressor was around $1000 but it gets used for alot of things that arent always body work.
What it will cost you depends on what you have already, like tools, how skilled you are at doing it, and how rough the car is.
Grimms fastback and mine are more along the lines of resurecting a parts car than a typical paint job. So ours will be more expensive and labor intensive. At least I got a good roof, and only slightly rusted door jambs with my steering column..
Figure the average DIY job already posessing the tools needed and using quality yet inexepensive materials will run you around $1500-$3000 depending on how much the paint costs, because some colors and types are alot more than others.
I am using NASON stuff for the most part.
Old Feb 28, 2007 | 05:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
My car had minimum rust. There was a spot on the lower front corner of each door, and the rear quarter panels. The car was stripped. The doors, hood and trunk lid were removed and the entire car sand blasted. Then new metal was welded in, new headliner, new weather stripping for the whole car and a new front windshield, and the paint job.....all for just right at $5,000.00 That was 10 years ago, so maybe 7 thousand today.
Old Mar 1, 2007 | 12:37 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
actuall body work and paint probably into it for about 1000$ idk know exactly i replaced both doors and front fenders and hood but i didnt have an extraordinary amount to do
Old Mar 1, 2007 | 12:53 AM
white69mach1
im going to pay somebody to do it so i was just wondering what i might be in for but i do live in mississippi and stuff is cheaper then most places im hoping its not going to go over 5,000 but im no set on it being that
Old Mar 1, 2007 | 12:54 AM
shr's Avatar
shr
i have about 700 in metal, and did all the work myself.....so i would try to do it yourself, try on some thing you think is easy and it jsut might be! o- will probably have a total of like 1100 in materials (metal,fillers,primer, sealer, and paint) but if you have shops do it, it will be at least 2500.00
Old Mar 1, 2007 | 01:09 AM
white69mach1
well i started with a 15,000 budget but i already had heads so 5,000 for the engine 408 stroker still need ignition and a tranny because i have a fmx probly going to go with a c-4.i need to rebuild the front end and i need wheels.ohh yeah and a carb i wonder if i will make it on that budget
