Subframe connector PKG
Old Mar 3, 2007 | 02:11 AM
66JameStang's Avatar
66JameStang
Default Subframe connector PKG
Well I am looking for a good subframe connector package that will be able to contain my drive shaft if it just so happens to come loose from the rear end. I have found one on mustangsunlimited and I was wondering if any of you have used this one/ what you think.
http://mustangsunlimited.com/itemdy00.asp?T1=SFC1+01
I am also up for other suggestions. Thanks
Old Mar 3, 2007 | 05:25 AM
andrewmp6's Avatar
andrewmp6
Default RE: Subframe connector PKG
says sites down for maintenance what your talking about is called a driveshaft loop its ok on a street car but if you drag race with slicks you have to have it and few other like scca road racing they make you have one
Old Mar 3, 2007 | 08:57 AM
dnswwood's Avatar
dnswwood
I have a similar question.What is everyone's opinion of which sub-frame connectors are the best one's to use on a daily driver.the one listed above is a nice unit although pretty expensive.Im not sure i need all that for a daily driver though?
what do ya'll think?
thanks Jeff
Old Mar 3, 2007 | 01:27 PM
JamesW's Avatar
JamesW
Here's what I used.
http://www.midnightdsigns.com/Mustang/subframe.html
Old Mar 3, 2007 | 03:02 PM
66JameStang
ORIGINAL: JamesW
Here's what I used.
Do you take your car to the track or is your car a cruiser?
Old Mar 3, 2007 | 03:04 PM
66JameStang
ORIGINAL: andrewmp6
Andrewmp6 what did you use for your subframe? I am definately planning on running my car at the track when my swap is complete, is there any particularsetup you suggest?
Old Mar 3, 2007 | 05:56 PM
Jamison's Avatar
Jamison
heres a pic of that setup in my 64 1/2 restomod coupe. one of the best bang for the buck things you can do to your car.
I added the rack and coilovers at the same time too though. plan on doing a custom exhaust i had to.
[IMG]local://upfiles/45128/ECFEEE8B31E647D699638A3EC277115F.jpg[/IMG]
Old Mar 3, 2007 | 06:31 PM
JamesW's Avatar
JamesW
I haven't taken it to the track, but I wouldn't hesitate while using these subframes.
Old Mar 3, 2007 | 06:59 PM
white69mach1's Avatar
white69mach1
im looking for 500 hp is subframe connectors going to be enough to handle it i realy dont wana go a rollcage
Old Mar 3, 2007 | 10:52 PM
mikethebike's Avatar
mikethebike
Have you looked at Heidt's? They have one for $250.00 with the loop. Plus you can upgrade later to the 4-link or if you need to go with a 9-in you can always spring for the irs. I know it cost a lot but if you go with a 9in, 31 spline NEW you will have $3k in that.
In answer to the 500 hp without a rollcage.....you can do what you want, but if I had 500 hp in an early Mustang I'd put a cage in the car. (a custom built 10 point cage).
