electric choke
Old Mar 4, 2007 | 09:57 PM
  #21
NorCalTroy's Avatar
NorCalTroy
Default RE: electric choke
OK, it does actually start? Is the choke open or closed?
Old Mar 4, 2007 | 10:04 PM
  #22
69stangcoupe's Avatar
69stangcoupe
it starts up and dies, the choke is closed when ready to start, then when you start it and it dies and is completely off the choke is open a little bit
Old Mar 4, 2007 | 10:27 PM
  #23
NorCalTroy's Avatar
NorCalTroy
The choke being closed when starting a cold engine is correct. Next step would be to see if it is getting fuel and spark. Since it does actually start, I'm guessing it has both. So, is it getting the correct amount of fuel (clogged fuel filter, bad fuel pump, unadjusted carb, maybe even bad fuel)? Or the correct spark (bad coil/cap/rotor/wires/plugs, incorrect timing)?
Old Mar 5, 2007 | 12:12 AM
  #24
6mustang6's Avatar
6mustang6
i broke both lines off my carb, on accident. It still starts up fine. One line goes into the round black, thermo type thing. Another one goes into a line that runs in right by the choke.
Old Mar 5, 2007 | 12:25 AM
  #25
NorCalTroy's Avatar
NorCalTroy
6mustang6-
I'm guessing even though your car starts, your choke is not operating correctly. It is probably not opening which means your air/fuel mixture will be rich once the car warms up. I'm not sure what problems could occur in the future, other than poor fuel mileage or maybe fouled plugs. Hopefully someone else will chime in with their two cents.
Old Mar 5, 2007 | 12:50 AM
  #26
69stangcoupe
i wish i could narrow this down more.
Old Mar 5, 2007 | 12:55 AM
  #27
NorCalTroy's Avatar
NorCalTroy
ORIGINAL: NorCalTroy
I'm trying to help you narrow it down, 69stangcoupe. When was the last time you changed your fuel filter? Can you tell if there is plenty of fuel getting into the carb? Is the fuel fresh? Have you changed the cap/rotor/wires/plugs lately? Is the timing set properly?
Old Mar 5, 2007 | 11:04 AM
  #28
boeing747arowair's Avatar
boeing747arowair
sry to steal the thread but i have an extremely similar issue; on the 1 bbl carb it seems to be missin the same tube that leaves the choke housing. where does this go on the I6 since this tube seems to have been removed by the PO. thanks alot and sry again
Old Mar 5, 2007 | 11:49 AM
  #29
Soaring's Avatar
Soaring
I ♥ Acer
The tube runs down to the exhaust manifold where it sticks into the manifold and runs up to the round black choke mechanism. When the engine warms up, the heat from the manifold travels up through the tube, warms up a spring in the black thing and as the spring relaxes, it opens the butterfly on the choke. Without the tube, you will need to devise a manual choke so you can open the butterfly yourself.
Old Mar 6, 2007 | 12:04 AM
  #30
boeing747arowair
Thank you sir!
