engineswap help
Old Mar 4, 2007 | 03:42 PM
shhswrestler215's Avatar
shhswrestler215
Default engineswap help
right now i have i 250 straight 6(it is out of a 72 mavrick, a previous owner put it in) i want to put a v-8 engine in it i was wondering if i could put a 460 in it and how hard it would be to do the swap i no the basic stuff ill have to do ( like mounts, suspenison upgrades amoung other things) any help is gratly apreciatedif it cant be do will a 390 or a 351 fit
Old Mar 4, 2007 | 03:54 PM
paddy187's Avatar
paddy187
Default RE: engineswap help
suspension, transmission, rear axle will most likely need to be made stronger check the faq
Old Mar 4, 2007 | 04:56 PM
middiepride's Avatar
middiepride
ORIGINAL: shhswrestler215
if you plan to put it in that 65 you're gonna have to eliminate your shock towers and put in place a mustang II suspension or similar. i'm not ever gonna say not go for it but be prepared for an *** load of work or to empty that fat wallet. either way you're probably gonna anyway. 351 will go in with a header swap if you have the v8 suspension in the car. 390 is in the same boat as the 460.either way,good luck with your decision
Old Mar 4, 2007 | 05:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
Do yourself a favor, and stroke a 302 then put some AFR 185 heads, a decent cam, a weiand stealth intake, a decent 4 barrel carb with about 650 cfm, some nice ceramic coated headers followed up with a2 1/2" exhaust system with an X pipe and series 40 Flowmaster muffs with turn downs right out of the muffs. That is all the kid car you will need. It will be powerful and loud. But, the first thing you are going to have to do is get a decent transmission and rear end, and upgrade your suspension to the V8 suspensuion, so you might as well get the disk brake conversion so you can have 5 lugs on the wheels so you can buy some nice wheels. Let's see.........that's about $30,000.00 all told. Wanna play, or do you want to fix that 250 six banger up so you can play at a whole lot less money?
Old Mar 4, 2007 | 06:45 PM
66JameStang's Avatar
66JameStang
Go for it man sounds like an awesome project, a lot of work but an awesome project.
Old Mar 4, 2007 | 07:32 PM
latamud's Avatar
latamud
ORIGINAL: JRD
I second that motion.
Not mine, 460 in a 65.
Old Mar 4, 2007 | 09:50 PM
Mustang Boy's Avatar
Mustang Boy
throw a turbo and 2brl carb on the 250 put a stronger tranny and rear end and call it a day cause itll be pretty fast then you can put a cam and a few other goodies and have a sick mustang
but if you do decide to swap just send the 250 and all of the motor mounts my way cause i could really use it
Old Mar 4, 2007 | 11:12 PM
shhswrestler215
i no this is probaly gonna sound stupid but what is a mustang 2 suspension i am only 17 and dont no too much just picking up here and there also will the suspion work if i take the front supension fro a 70s lincoln ( where i plan on geting the rear, engine, tranny, and anything else that i can for the project i can ) i no it just wont bolt on but will that type of suspion work if not what type of car would have a mustang two supension thanks for all the help
Old Mar 5, 2007 | 04:30 AM
andrewmp6's Avatar
andrewmp6
mustang 2 is the front suspension off a mustang2/pinto or a kit unless you can weld its pricey your best bet is rebuilding that 6 with more power or a 302 like soaring said but any v8 you put it in is gonna be alot of work good luck
Old Mar 5, 2007 | 05:36 AM
paddy187's Avatar
paddy187
If u stay with the six fordsix.com will have lots of info to make that puppy keep up with stock 302/289 and some modded ones as well, i.e. better heads, turbos etc
