Daily driver upgrades
Old Mar 6, 2007 | 01:52 AM
green_blurr's Avatar
green_blurr
Default RE: Daily driver upgrades
I have installed petronix ignition I have noticeda huge different in the way the engine fires right up instantly.smooth power response aswell. I have heard about the instruments in the dizzy
crapingout on some people but i dont know why it would. But i am happy with it no problems here.
latamud's Avatar
latamud
1" or 1 1/8" front sway bar, roller spring perches(http://opentrackerracingproducts.com/rollerperch/), Shelby drop, aluminum crossflow radiator, granada swap, T5 swap, new shocks if needed, roller pedals kit(http://www.mustangsteve.com/clutchbearings.html), replace old worn out bushings with polyurethane,
Old Mar 6, 2007 | 05:26 AM
andrewmp6's Avatar
andrewmp6
depends on where you live good heat or good ac are a must to me. so is front disc 3 point seat belts all the safety parts should be on the top of your list. then theres things like radios speakers leather seats etc etc
Old Mar 6, 2007 | 02:03 PM
blue66coupe's Avatar
blue66coupe
Ha! some of you guys couldn't help yourselves on the performance mods.... This will just be a daily driver, and probably will be my wife that drives it mostly ( it is her car, after all...) so I don't think she'll be too much into racing anyone....
But, the safety mods are definitely important, and those will be included for sure. On the column swap, what is the preferred column to use?
Old Mar 6, 2007 | 02:39 PM
JMD's Avatar
JMD
ORIGINAL: blue66coupe
We used a kit from Flaming River, but we changed to rack and pinion steering as well. You should have plenty of stock choices available on Mustangs Unlimited, Ididit, Etc......
Theswap was easy, with the only difficult (just a little) issue being the wiring of the conversion plug for the column wiring.
You can get a colapsable column with tilt from Ididit, that should be a bolt in.
Old Mar 12, 2007 | 10:12 AM
Norm Peterson's Avatar
Norm Peterson
I don't think I've ever done a mod without slanting it toward squeezing just a little more performance of some sort out of the car. Not that every car has to be a race car, but it's nice to have a little extra "sparkle" in the way a car drives to make you feel good about the work that you put into it. Even the '66 that wasmy daughter's first car - I did put quite a bit of work intoit - was worked over with this philosophy very much in mind.
BTW, don't underestimate the wife when it comes to occasionally driving with enthusiasm - a friend of my son's hasa somewhat embarassing memory that he'll probably never be allowed to forget.
Norm
PaulH2
20
Jan 31, 2016 09:48 AM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
