Tools and parts needed to install a suspension
I finally got my grab a track suspension complete kit (its actually the Kit from Laurel Mountain Mustang) Not Grab a Trak but anyways im getting ready to install it, i need to know what tools and what else do i need before i start this project since my mustang is my only vehicle, once i start it would be hard for me to go buy stuff, I heard i need Chassi Grease... any thing elese?
RE: Tools and parts needed to install a suspension
A good set of jackstands,coil spring compressors,2lb hammer,grinder with cutting disc,floor jack and a prybar in addition to a complete set of wrenchs and sockets
Silver Pony pretty muchsaid all of it. I just came upstairs from working on my suspension.
You will need 4 jackstands, floor jack, the complete set of wrenches and sockets, a sawzaw with acouple fine blades or a cutting wheel(grinder with a cutting blade), the hand sledghammer for knocking the balljoints apart, a CENTER spring compressor(1 piece), and a another person for removing the differential. I did it myself but do not advise it haha
I pulled out the rear axle on my 71 myself.
1) get the car up on stands (no stands under rear axle, you can leave the wheels on).
2) Loosten U-bolts, shackles, and front spring mount.
3) Support rear axle with jack.
3) Remove rear shackes and lower axle with jack.
4) Remove u-bolts.
5) Remove bolt from front spring mount and remove springs.
Install is also easy, about the heaviest thing you have to handle is the leaf springs, but you only have to lift one end.
4) Remove u-bolts.
What is the cutting wheel/sawzall needed for? What is being cut?
Might need a pickle fork to get the ball joints loose.
