Lowered Mustang
Old Mar 10, 2007 | 11:01 AM
Trigger70's Avatar
Trigger70
Default Lowered Mustang
I have lowered my hardtop 70 recently and I am curious as to whether I need to add the negative wedge kit to my upper control arms. I did the Shelby Drop along with 620# 1" lowered springs and in addition removed 3/4 coil which dropped the car approximately 3.5".....any thoughts??
[IMG]local://upfiles/63150/C41E6E41945E46419E8E9EF1BFB1B21F.jpg[/IMG]
Old Mar 10, 2007 | 12:17 PM
05SDI's Avatar
05SDI
Default RE: Lowered Mustang
Do you have any better pics? Dropping 3.5" seems like a lot. I would like to see what that looks like.
05sdi
Old Mar 10, 2007 | 12:43 PM
Trigger70's Avatar
Trigger70
Before I lowered the car the front was 15-3/4" and the rear was 15-3/8". Nowthe front is 12-5/8" and the rear is 14-3/8" so the front ws actually droped about 3" rather than 3-1/2". This car was very high when I started. I am having problems posting better pictures....not sure I doing it right. The files seem to be too large.
Old Mar 10, 2007 | 12:46 PM
Phatboy's Avatar
Phatboy
upload your full size pics to www.imageshack.org
then use the html line that says for forums to link us to the full size pic.
Old Mar 10, 2007 | 03:14 PM
2bav8's Avatar
2bav8
The negative wedge kit is only needed when the upper control arm is lowered more than 1".
In you case, you do not need it.
Old Mar 10, 2007 | 05:17 PM
Trigger70's Avatar
Trigger70
I only lowered the control arm 1" but I wanted to make sure the additional spring drop was not putting the ball joints in a bind. Thanks for the info.
Old Mar 10, 2007 | 05:20 PM
Mustang Dad's Avatar
Mustang Dad
12 and 5/8 inches?? Where are you taking yourmeasurements at? The usual place to make the front end height measurement is at the center of the wheel well to the ground. If its at the topof the wheel well to the ground, you gotta have tire sticking up through the top of the fender. I lowered our '65 with the Shelby drop and trimmed off 1/2 coil and got about a 2 inch drop at the wheel well but it turned out to be too much, tires rubbing on the fender lips in turns. We replaced the top coil spring isolator, added a couple of adjustable coil spreaders and got it back up to just below the top of the tire. The ground to wheel well measures right at 24 inches now, and we got the nose down stance that we were looking for.
Old Mar 10, 2007 | 05:29 PM
Trigger70's Avatar
Trigger70
I took the measurement from the center of the hub up to the bottom of the fender.
Old Mar 10, 2007 | 05:38 PM
Trigger70's Avatar
Trigger70
http://img249.imageshack.us/img249/8208/rearviewod9.jpg
Old Mar 10, 2007 | 05:49 PM
Mustang Dad
Thats a good looking stance you have there. Not too low and not to high. And its a good lookin car too!
