matching numbers
Old Mar 12, 2007 | 06:19 PM
bjktz's Avatar
bjktz
Default matching numbers
im looking to buy a 1966 how can i check to see if all the numbers match and where are they
im looking at 2 different ones is it better to buy one with matching numbers or one in better shape im looking to restore it.
Old Mar 12, 2007 | 06:22 PM
grruminator78's Avatar
grruminator78
Default RE: matching numbers
umm really there is no such skunk
Old Mar 12, 2007 | 06:27 PM
67t5ponycoupe's Avatar
67t5ponycoupe
On these old Mustangs there were no VIN's stamped in the blocks of transmissions.All you can do is make sure it is a block from the right general era. They did have date codes on the sheet metal parts. This really only makes a difference if you are buying something very rare. If you just want to restore something I would get something in good condition and don't worry about matching numbers.
Old Mar 12, 2007 | 06:29 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
Sorry man, 66's did not have VIN numbers on the engine block (other than K-codes) so there is no such thing as "numbers matching" for 66 Mustangs. I'm not sure about the tranny, I do not think they had VIN numbers on them (except maybe a 4-speed?) as well. It is kind of like when someone says they did a frame off restoration on their Mustang, Mustangs do not have frames, so you cant doa frame off restoration. Forddid notput VIN numbers on their engineblocks till 1968.
Old Mar 12, 2007 | 06:31 PM
67t5ponycoupe
VIN's on the blocks in 68? Are you sure about that? I've never seen a VIN on any block except the HiPo's
Old Mar 12, 2007 | 08:02 PM
289FB's Avatar
289FB
bjktz unfortunately it is not such a thing as a matching # on a 66 except a K code the only thing that you can find are engine cast numbers removing the starter and on the maniful and in some cars you can still find the aluminum tags attach to the engine carburqtor steering box trasmission and ( I think ) on the rear end, then check the date on manufacture of the car and if the casting # and the tags indicate that thos parts are with in 3 to 4 weeks before you can safe asume that they are the original parts and the car is "original enclose is some of the pics of the casting and aluminum tags # hope this help you
[IMG]local://upfiles/31083/4F0DE64F7CD7452CA1E63EC2C299637C.jpg[/IMG]
[IMG]local://upfiles/31083/5C6A4A4BAA5548688BD49AFE06964CE9.jpg[/IMG]
[IMG]local://upfiles/31083/C8204AA0E0A14A2CB2362A8235D021E5.jpg[/IMG]
[IMG]local://upfiles/31083/14833EC2F60B4991BA83AED5A35B1CDE.jpg[/IMG]
[IMG]local://upfiles/31083/687AE676E1BF40A1AA331A66DFA1E4B6.jpg[/IMG]
Old Mar 12, 2007 | 08:05 PM
289FB's Avatar
289FB
here are someother pics
[IMG]local://upfiles/31083/B94A21B997E8498385BF7F6AE07363AA.jpg[/IMG]
[IMG]local://upfiles/31083/1BEB0B8C8E664FA288D474CA8581B3AF.jpg[/IMG]
Old Mar 12, 2007 | 09:00 PM
289FB's Avatar
289FB
I forgot to mention that the serial # on the driver's inner fender mach the ID tag on the driver's door, the other tag is attach to the inner fender on the passenger side ( no tag if the car isassambled on San Jose CA) give you all the info such as body, color,trim,date of manuf, D.S.O, axle and trans... the one on the door give you the year, plant, body series engine and the unit #...but many of the tags if any work such as driver's door change, work on the inner fender, on the engine, carb etc were never replaced and gone to the trash..here are some pics of engine tag
[IMG]local://upfiles/31083/AE8DA25B5C894257A2F85535F6AD8F6E.jpg[/IMG]
[IMG]local://upfiles/31083/737154065DB34719B9A21E2C93E8E273.jpg[/IMG]
6bangr
Feb 15, 2016 07:40 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Sep 23, 2015 01:28 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
