proportion valve
ORIGINAL: Soaring
I just now realized that we have some guys in high school on here who may be looking for a more simpler explanation about the physics of the front disk and rear drum brakes and what the proportioning valve really does.
The proportioning valve reduces the pressure to the rear brakes. Regardless of what type of brakes a car has, the rear brakes require less force than the front brakes.
The amount of brake force that can be applied to a wheel without locking it depends on the amount of weight on the wheel. More weight means more brake force can be applied. If you have ever slammed on your brakes, you know that an abrupt stop makes your car lean forward. The front gets lower and the back gets higher. This is because a lot of weight is transferred to the front of the car when you stop. Also, most cars have more weight over the front wheels to start with because that is where the engine is located.
If equal braking force were applied at all four wheels during a stop, the rear wheels would lock up before the front wheels. The proportioning valve only lets a certain portion of the pressure through to the rear wheels so that the front wheels apply more braking force. If the proportioning valve were set to 70 percent and the brake pressure were 1,000 pounds per square inch (psi) for the front brakes, the rear brakes would get 700 psi.
I have a '66 with front discs, and I 'm getting ready to switch over to a dual MC with a factory style combo valve. The only source I've found for a new combo valve is NPD, cost$120. This valve eliminates any need for adjustment.
ORIGINAL: baddog671
No need for insults now...
ORIGINAL: Soaring
ORIGINAL: baddog671
I am 19 but I have a legit reason for asking u so many questions. I dont have anything to inspect and see how it works. I just have the MC and the brakes.
ORIGINAL: Soaring
It's a shame the government/state schools took out auto mechanics from our high schools. I am sorry you are among the many thousands of young men who were not given the opportunity to be exposed to a hands on high school auto mechanics course where you leaned how to do much of what we have been discussing on here.
ORIGINAL: baddog671
BWAHAHAHAHAHAHA!!!!!!
I was in Vo-Tec for about a month and a half before deciding I would rather take a normal class instead. I learned more about lawn mower motors than real motors and all I had to work on was a Saturn motor and all that was asked of me was to r&r the plugs and put the wires back on in order.
They didn't even show me how to change the oil! I learned more form trial and error in my own car than vo-tec or working in Pep Boys.
Best lesson: If your rotor bearings fall in the dirt, clean out all the grease and make sure there is no grains of sand left in the bearings before trying to re-install them. They WILL lock up and they will get stuck on the spindles.
That was a mess!
The prop valve can go anywhere ON THE REAR LINE between the MC and rear where the line splits out to the two drums. Easiest spot to put it would be near the firewall/MC.
[blockquote]
ORIGINAL: Soaring
No, you don't just put it anywhere. You connect it to the front bowl of the dual MC and run it to the back brakes.
[/align]
[blockquote][/blockquote]
