Brake Conversion Kit
Old Mar 14, 2007 | 12:00 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Brake Conversion Kit
ORIGINAL: baddog671
I may be wrong, but isnt that link in the first post an original setup?And 575 is about the best Ive seen on the net, but you can get it half that price at a local store if you put it together yourself. And shipping is going to kill you.
Can you really get it at a local parts store at half that price?
Old Mar 14, 2007 | 01:29 AM
baddog671's Avatar
baddog671
Ok, I added it up and maybe not HALF, but a hell of a lot less. Personally I dont need some of the parts becuase my car already has old granada brakes on it, so it will be about half for me.
Even still, your going to cut shipping which will easily be 60-100 bucks I would think...
Old Mar 14, 2007 | 01:39 AM
andrewmp6's Avatar
andrewmp6
the granada swap you buy as a kit or in parts only thing id use used is the spindles rest get new. or theres always http://www.mpbrakes.com/ and http://www.abspowerbrake.com/ if you want good disc brakes with out spending alot for baer ssbc wilwood etc etc. just let us know which ones you buy and how you like them
Old Mar 14, 2007 | 01:41 AM
ndnboy's Avatar
ndnboy
$575 doesnt sound bad, 1/2 off sounds even better.
I have beenthinking about getting front disc and have read some postand FAQ artcles, I missed the part were 14" rims wont work. It will run me a bit more having to look at new wheels, etc.
Any applications out there for 14 " rims?
Old Mar 14, 2007 | 01:43 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Just to add fuel to the fire. Here is one I wanted to try. http://www.mpbrakes.com/products/pro...product_id=313
Old Mar 14, 2007 | 01:46 AM
baddog671's Avatar
baddog671
Yes, the only parts Im going to reuse is the spindles and the caliper brackets, but that alone cuts alot off the price. I think a nice set of spindles on ebay are about 75...
Old Mar 14, 2007 | 03:54 PM
iamdiffrnt's Avatar
iamdiffrnt
Dennis' kit (discbrakeswap) comes with new spindles, and the spindle geometry has been corrected for 65-66 to prevent the bump steer issues associated with the swap. Hope this helps
Old Mar 15, 2007 | 02:13 AM
heavensonfire's Avatar
heavensonfire
Thanks so much for the ideas something else I was wondering is with some other upgrades I had in mind being a problem. I've looked at the rack and pinion set and all use original suspension set ups from what I've understood. Now some of the suspension upgrade kits I've looked at have said for use with the stock disc brake spindles. I was just wondering I have 4 drum on now obviously. What would be the best suspension kit to go with this without any conflicts. I'm not going for an all out track car, but I do want it to be an above average DD. Once I've decided on the brakes and suspension and those are in think its going to be a 347 stroker next..But I'm in planning stages any suggestions?
Old Mar 15, 2007 | 03:28 AM
connor90's Avatar
connor90
ya i used dennis' setup and i highly reccomend it. his instructions are a little more complicated than they need to be imo but it works.
Old Mar 15, 2007 | 12:16 PM
Bentworker's Avatar
Bentworker
Check out Maier for suspension.
http://www.maierracing.com/
Their setup isn't too expensive and seems to work.
