67 Alternator Wiring
Old Mar 15, 2007 | 03:04 AM
onuliakattack's Avatar
onuliakattack
Default 67 Alternator Wiring
Im trying to figure out the wiring coming from the alternator, i have yet to find a wiring diagram that specifies where each wire goes from each post on the alternator, my mustangs charging system isnt working and alot of the wires are all screwy and jimmy rigged, could someone tell me where each wire goes? thanks in advance.
[IMG]local://upfiles/22269/3540751FE55444488E4C9ED5B0BE3112.jpg[/IMG]
Old Mar 15, 2007 | 04:35 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 67 Alternator Wiring
If you buy a new harness is will be easy. The harness comes with a connector that will only allow you to hook it up one way. I do know that you only hook up the ground the Batt and the field terminals. Batt and ground should be easy to figure out. Field will be the one left over. You don't hook up the stator.
Old Mar 15, 2007 | 09:37 AM
sxs191's Avatar
sxs191
http://www.cjponyparts.com/TechAltWiring.asp This is for a 65-66 but basically same concept.. If you still need more info I can look at my 68's.
Old Mar 17, 2007 | 10:43 PM
onuliakattack
i hooked up everything right and im still getting no charge to my battery, i then took my alternator to the auto parts store and they said it was bad, i bought a new one and its the same thing, no charge. I have the BAT terminal hooked to the battery, the white plastic terminal going to the voltage regulator on the terminal furthest to the right, and the alternator is grounded. Any ideas as to why i wouldnt be getting a charge at all? shouldnt i be getting a charge no matter what if my BAT terminal has a wire running directly to the posotive terminal?
Old Mar 17, 2007 | 10:47 PM
67t5ponycoupe
No I think that only supplies power to excite the field on the altenator.
Old Mar 17, 2007 | 11:11 PM
onuliakattack
Than what sends power from the alternator to the battery/solenoid?
Old Mar 17, 2007 | 11:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Did you replace the voltage regulator as well when you replaced the alternator? If not, then do it.
Old Mar 18, 2007 | 02:08 AM
67t5ponycoupe
Power goes from the Batt/solenoid to the alt not the other way around. The output of the alt goes to the regulator.
Old Mar 18, 2007 | 03:35 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
why is the stator terminal there if it isn't used
Old Mar 18, 2007 | 04:14 AM
67t5ponycoupe
Are ya not believing me? I don't know, I just make 'um run I don't design the freaking things. If you click on this same link that was posted earlier it will tell you the same thing. http://www.cjponyparts.com/TechAltWiring.asp
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
