Horn not working
Old Mar 17, 2007 | 02:03 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default Horn not working
I tested the horn today, cause I need it to work for state inspection, and no luck. I see the wires from the horns go to a 4 position connector on the far right (drivers) side of the firewall. After this, I can't find it inside the cab. Anyone know the color of it?
edit: Just found out it should be blue-yellow
Anyone know where to start on getting this to work? I've heard problems with something about the turn signal switch. When I got the car, there was a "Ford Motor Company" white box in the trunk and inside was a turn signal switch - apparently the old one which was replaced.
Sorry, rambling...any ideas on where to start? Thanks
Old Mar 17, 2007 | 02:22 AM
stanging's Avatar
stanging
Default RE: Horn not working
First check the horn manualy, check the contacts on the horn , you'll have to take the horn ring off to check. What year is the car?
Old Mar 17, 2007 | 02:46 AM
mySAVIOReigns
it's a 66
To remove the horn ring (don't have the mustang with me at the moment), do I need any special tools?
Old Mar 17, 2007 | 02:49 AM
stanging's Avatar
stanging
No, you should be able to turn it counter-clockwise and it will come off.
Old Mar 17, 2007 | 02:54 AM
mySAVIOReigns
ha! awesome...So what exactly am I looking for here with the contacts?
Old Mar 17, 2007 | 03:09 AM
stanging's Avatar
stanging
Make sure they are not broke or worn out and to see if they are making contact with the horn ring.
Old Mar 19, 2007 | 09:02 PM
mySAVIOReigns
Okay, bringing this one back...
I had a friend tell me a trick to see where the problem was. I took a piece of wire I found and pressed the horn ring in. I then took the wire and touched the two screws with the springs around them. This made the horns honk, so I know that the horns aren't screwed up, and the electricity is getting there. Now, where do I go from here? Which part will I need to buy to correct the problem? I assume that it is not making contact, though to be honest, I don't understand the whole process Thanks
Old Mar 19, 2007 | 09:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
The contacts on these old horns wear out, so you have to break a fuse into, and get all the glass out. Then use the metal caps to cover the contact points. That way, it will make contact, and you will once again have a horn.
You might also get some good out of reading this article.
http://www.mustangmonthly.com/projec...teering_wheel/
Old Mar 28, 2007 | 02:35 AM
mySAVIOReigns
Ahhh....
This is driving me nuts. I replaced the rubber grommet in the horn button. Now, I can barely get the horn ring onto the wheel??? It's the same size grommet, so I can't see why it is doing this. After much frustration, I took the plate in the horn ring (with the 2 contacts on it) and put it on the center of the wheel. I checked and there IS contact. Why is it still not honking? Thanks again
Old Mar 28, 2007 | 11:57 AM
mySAVIOReigns
Well, I'm sorta bumping this bc of no reply. Just to be on the safe side (for getting an inspection) I went and bought a universal horn button. I assume 1 +12V wire, horn wire goes in one, and it should be grounded. Is that right? This is very similar to what I got
