3 or 4 speed? / discs brakes?
Old Mar 19, 2007 | 12:24 AM
Yellow66's Avatar
Yellow66
Default 3 or 4 speed? / discs brakes?
My newly purchased 65 fastback has a 3sp gearbox. It is about to undergo a resto and i purchased it "not running". If the 3 speed is in good condition i will leave it be, but if it is in need of a rebuilt, should i do this (and keep original), or put a 4spd in?
It is also running drum brakes all round and i was thinking of converting to discs up front. I was considering getting a conversion kit from theUSA (live in Australia)when i inport some other parts. What do you guys recommend re disc conversion kits or should i just stay with the drums (car will only be driven 1-2 times a week)?
Cheers
Old Mar 19, 2007 | 12:42 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 3 or 4 speed? / discs brakes?
Disc all the way mate! If you can find a good 4 speed that would be much better than the 3 speed but the trend lately is to put late model 5 speeds in the early stangs. I don't know if you will have 5 speeds down under or not. Maybe in those ford things you guys have down there that are like a Ranchero's. You know, car front and pick up truck back. What do you guys call those things anyway?
Old Mar 19, 2007 | 12:46 AM
fast65's Avatar
fast65
Go with the4-speed, I woudn't go with discs if it's only driven two times a week, go for more power!
Old Mar 19, 2007 | 01:06 AM
LCC's Avatar
LCC
4 speed. Nothing bad about properly built drums, they work just fine for cruising on weekends. Wait till you have more done to the car to spend the money...
Old Mar 19, 2007 | 03:54 AM
JMD's Avatar
JMD
4 or 5 speed! / Yes!
Old Mar 19, 2007 | 05:55 AM
andrewmp6's Avatar
andrewmp6
hes a aussie they have harder laws on car safety then the usa. id go with the 4 speed or a t5 if you can find one and 4 wheel power disc are a nice thing to have. you might not have to import parts your early ford falcon is the same one as the usa which is what the mustang is based off i believe you call it a xb there .id talk to www.rrs-online.com they are a aussie company might know a way to get you 4 wheel disc cheaper then importing them good luck let us know what you do go with
Old Mar 19, 2007 | 12:30 PM
mikethebike's Avatar
mikethebike
ORIGINAL: Yellow66
It is also running drum brakes all round and i was thinking of converting to discs up front. I was considering getting a conversion kit from the USA (live in Australia) when i inport some other parts. What do you guys recommend re disc conversion kits or should i just stay with the drums (car will only be driven 1-2 times a week)?
Cheers
"There is no such thing as a good used 4-speed. There are good 4-speeds and used 4-speeds but the 2 are mutually exclusive"
I coined that phrase, by the way.
My advise is to sell the 3-speed and go for the Tremac 5-speed. When you do get the Lakewood bell housing and hydraulic clutch kit and you are set for life. I know it cost some money but you will spend just as much rebuilding stock transmissions. And as far as disc conversions....again...bit the bullit and get the Wilwood Super-Lites with 4 piston calipers and 12 in drilled/slotted rotors.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
maestro1024
Sep 21, 2015 02:40 PM
uberstang1
Sep 21, 2015 09:04 AM
Sep 8, 2015 11:50 AM
