Missing Dataplate
Old Mar 19, 2007 | 01:47 AM
tlrbjc's Avatar
tlrbjc
Default Missing Dataplate
hi all. I was wondering if anyone could help me. I purchased a 66 mustang coupe and after inspecting the driver-side door, i noticed that the vin on the dataplate didn't match my vin #. Here i found out that the door was replaced with a 65. Ihave decoded what i can about my car from the vin #, but can't get any info about the tranny, interior, axle, etc.
Is there anywhere where someone might have this info on file? Ford or somewhere? I noticed in the door jamb by the door hinges is a Tennessee state plate stamped with the vin #. Don't know what that is there for but it matches my Vin on the title.
thanks for all the help.
tlrbjc
Old Mar 19, 2007 | 01:50 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Missing Dataplate
sory all records pre 67 were destroyed by ford
Old Mar 19, 2007 | 02:25 AM
mustanglover66's Avatar
mustanglover66
I have the same problem we are just sol, I plan on getting a new data plate when I finish the car with the info of what I put in it but the vin will let people know its not a match to what the car was built with
Old Mar 19, 2007 | 03:14 AM
gothand's Avatar
gothand
Most of the data plate items can be figured out by looking at the items you have now. In all likelihood, your car has probably not been regeared or had a tranny swap. To find out your paint color, look behind the door panels. Even if the interior color was changed, you'll likely find some of the original color somewhere on the door frame behind the splashshields or behind the window felts. For the body color, even the best painter is not going to be able to hide all the original spray. Look under the carpet if all else fails.
The only things you won't know with any certainty are the build date and district order code.
Old Mar 19, 2007 | 03:15 AM
tlrbjc's Avatar
tlrbjc
thanks for the reply guys. Actually i am lucky cause most of the stuff i have is probably original. (Color, engine, interior, transmission) But i am going to be like you mustanglover and just get a new one with few changes i am making.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
