Timing question
Old Mar 24, 2007 | 04:09 AM
green_blurr's Avatar
green_blurr
Default Timing question
I am using the early timing cover from the 289 on my 69 302 should the timing be set at 6 degrees behinde tdc? or right on tdc?
Old Mar 24, 2007 | 10:20 AM
MrMischief's Avatar
MrMischief
Default RE: Timing question
i believe its goin to be 6 deg BTDC, but your aftermarket setup may be a little different. you gotta play with it to get it properly timed.
Old Mar 24, 2007 | 11:19 AM
67coupe's Avatar
67coupe
I am pretty sure the covers and pointer are the same. 6-8 degrees BTC should do it.
Old Mar 24, 2007 | 12:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Somewhere between 6 and 10 BTDC. Mine is right at 10 and she runs like a scared rabbit with no pinging.
Old Mar 24, 2007 | 01:35 PM
67t5ponycoupe's Avatar
67t5ponycoupe
The pointers are not in the same place on a 289 and a 302. If you are using the 289 cover and the 302 harmonic balancer it will not work.
Old Mar 24, 2007 | 02:19 PM
green_blurr
I am using the timing cover from my 289 and the harmonic balancer aswell from teh 289
Old Mar 24, 2007 | 03:14 PM
kalli's Avatar
kalli
if you need to know if the marker actually points to dead center, then I couldn't think of another way then get rid of spark plug,
stick a welding wire down the thing and see for yourself where te piston has dead center (while turning the crank)
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
