Engine Mounts
Old Mar 25, 2007 | 08:46 PM
gmata's Avatar
gmata
Default Engine Mounts
I went to buy new engine mounts for my 1967 mustang with a 289. The brand name was Federated Auto parts. after hours and hours of trying to install the new Mounts i gave up! the mounts wouldn't match by a few milimimters but enough for not letting the bolt to get in. I have my engine just sitting on the mounts and they are not attached to the frame, does anyone know what brand of Mounts would fit my car?
thanks
Old Mar 25, 2007 | 09:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Engine Mounts
First of all, the driver's and the passenger side mounts are different. Make sure you are using the right one on the correct side. Also, the 67's had an early and a late style motor mount for the 289's. Your best bet would be to get the build date off the data plate on your door, then call a mustang vendor and order the correct ones for your car.
Old Mar 25, 2007 | 11:08 PM
mikethebike's Avatar
mikethebike
Just weld it in.
Old Mar 26, 2007 | 03:47 AM
gothand's Avatar
gothand
Pretty sure that the mounts for 66 and up are the same for both sides with the 65's being different for each side.
Old Mar 26, 2007 | 03:51 AM
JMD's Avatar
JMD
ORIGINAL: gmata
thanks
We got a cool looking aftermarket set of mounts for my son's 66, but we haven't put them in yet, so I dont know how it will go as far as an easy install,,,,, but they look really cool!![8D]
Old Mar 26, 2007 | 01:56 PM
gmata's Avatar
gmata
[/quote]
What kind of Mounts you got? and yes 67 Mounts are the same for both sides, they just go backwards.
im going to try a different brand see if that works
Old Mar 26, 2007 | 02:18 PM
JMD's Avatar
JMD
ORIGINAL: gmata
We ordered these from Mustangs Unlimited:
http://www.mustangsunlimited.com/ite...asp?T1=TCP1+01
I have them in my garage, they look like a quality product. I have test fit the brackets to their respective parts and the fit is perfect, but like I said, I have not installed them yet so I cant comment on the final fit, although it looks like a simple and easy process, that allows for a little adjustability.
Old Mar 26, 2007 | 02:44 PM
scott_m_mil's Avatar
scott_m_mil
We picked some up from autozone for a 67 with a 302 (same block) no problems.
Old Mar 26, 2007 | 03:05 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
200+ for motor mounts thats insane i would never pay that i would get some good poly ones for like 40 and i forget which brand had the strong mounts yet are soft enough not to fee each cyl fire
Old Mar 26, 2007 | 04:03 PM
JMD's Avatar
JMD
ORIGINAL: Brandontyler65
I can respect your point of view. We purchased this kit because we didn't have any brackets to start with whatsoever. When we started figuring the price for the entire mount system, combined with the aggrivation of aquiring some of the parts used we decided to go with this setup. It is a lot cleaner than the stock setup, and considering that we will be puting out about 500 HP, I thought they were a good investment.
The "vibration factor" does not concern me much, what vibration we get we will live with, but I don't think it will be that bad, the engine is ballanced.
I am wanting to say that these were priced at about $160.00 when my son bought these mounts, I think the price may have gone up since,I am not entirely sure about this, but I am pretty sure.
