ignition still
Old Mar 25, 2007 | 11:12 PM
eZ's Avatar
eZ
Default ignition still
still cant figure out whats up with my ignition. all i did was switch out the starter. install a single wire alternator. and now there is no ignition. is it possible that the old three wire alternator had a ground for the ignition?
[/align]
Old Mar 26, 2007 | 01:01 AM
eZ's Avatar
eZ
Default RE: ignition still
*bump* help!
[/align]
Old Mar 26, 2007 | 01:07 AM
Soaring's Avatar
Soaring
I ♥ Acer
The one wire alternator wire goes to the + side of the Solenoid. Now, start tracing the wires from the Solenoid to see where they go. Do you have a wire from the solenoid to the Coil?
Old Mar 26, 2007 | 01:20 AM
JamesW's Avatar
JamesW
ORIGINAL: eZ
[/align]
Ok...track back over what you did. Are all the wires hooked correctly to the solenoid? Did you reverse the S and I posts? Did you connect your battery back up? Ground back up?
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
