engine question
Old Mar 26, 2007 | 12:59 AM
robert912004's Avatar
robert912004
Default engine question
Would a engine makea rocker arm tapif you change the oil from 50 weight to synthetic 10W-30?
Old Mar 26, 2007 | 01:02 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: engine question
Yes, and only if the rocker arm was not adjusted correctly while using the 50 weight oil. If your rockers are adjusted to specs, then it won't make much difference which oil you use.
Old Mar 26, 2007 | 02:27 AM
Colorado_Mustang's Avatar
Colorado_Mustang
If your adjustment was 'just barely' with SAE50, then you will notice a light tap with SAE30. I would readjust with any oil change, just for assurance.
Old Mar 26, 2007 | 04:16 AM
JMD's Avatar
JMD
ORIGINAL: robert912004
yes it could make a rocker, or a number of other parts start tapping.
Old Mar 26, 2007 | 05:39 AM
longlive289s's Avatar
longlive289s
everything tap's in a old mustang
no, like everyone said, oil could be the the problem but just tighting down the rockers to spec
Old Mar 26, 2007 | 10:11 AM
mikethebike's Avatar
mikethebike
The lifter could be on its last leg. The 50 was thick enough to keep it quiet whee the 10/30 isn't.
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
