Carb. advice
Old Mar 26, 2007 | 10:01 PM
ZonaMuscle's Avatar
ZonaMuscle
Default Carb. advice
Need some advice please. I have 302 engine with an edelbrock performance intake on it. Im looking for a Carb for it. ive been told by a local store to put nothing bigger than a 500cfm in it. But ive been told that a 600cfm is the way to go. Any recommendations??? thanks
Old Mar 26, 2007 | 10:04 PM
67coupe's Avatar
67coupe
Default RE: Carb. advice
If you want to go with a vacuum secondary a Holley 600 works great on a stock engine. I run a 750 cfm on my 302 but it isn't stock and I have a low axle ratio.
Old Mar 26, 2007 | 10:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
You will get a lot of replies about hollies and such, but those are aftermarket carbs. Why not just put the original 4100 Autolite carb on there an call it a day?
Old Mar 26, 2007 | 10:42 PM
Yonco's Avatar
Yonco
holley 600 cfm 4150 is my best suggestion -Jon
Old Mar 26, 2007 | 11:02 PM
ZonaMuscle's Avatar
ZonaMuscle
That is another question i guess. Ive heard edelbrock is less maintance than a holley, but holley is more performance. As you can tell im new to the carb. thing. I mainly know EFI
Old Mar 27, 2007 | 12:52 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Holley DP FTW.[8D]
Old Mar 27, 2007 | 04:08 AM
gothand's Avatar
gothand
For a mild street engine, I'd go with a Holley with vacuum secondaries, either the Street Avenger 570 cfmfor $366 or a Holley 4160 600 cfm for $300. If you go to Holleys website, they have an interactive carb selector which will help you figure out what model will suit you best.
Old Mar 27, 2007 | 09:15 AM
roostracing's Avatar
roostracing
holley 4150 or aspeed demon...which edelbrock intake do you have? Is is a performer or performaer rpm? If it is a stock replacement performer intake than go with the holley 4150 (600cfm) vacuum secondaries...
Old Mar 27, 2007 | 11:31 AM
iamdiffrnt's Avatar
iamdiffrnt
While I like Holleys and have no issues with Edelbrocks, if you can find an Autolite 4100 cheaper I would go for the Autolite.
It's just a solid carb. Stick with the cfm recommendations (500-600).
LiquidDrink
Sep 29, 2015 10:06 AM
Ipaman
Sep 22, 2015 07:01 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
tramphardrocker
Sep 13, 2015 08:56 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
