disk brake conversion
Old Mar 27, 2007 | 01:19 AM
Tony R's Avatar
Tony R
Default disk brake conversion
I have a 65 that I am deep in restoring. I am trying to find a reasonably priced disk brake conversion. I dont know why but my brake petal in the car says dick brake but I have drums front and rear. What cars can I take the spindles off of to convert over? I would also like to find rear disks too if possible but they arent a high priority.
Old Mar 27, 2007 | 01:24 AM
JamesW's Avatar
JamesW
Default RE: disk brake conversion
Check out my website below for some info on front and rear disc brakes.
Old Mar 27, 2007 | 01:28 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Should be able to do the swap without changeing spindles as long as you are 5 bolt right now.
Old Mar 27, 2007 | 01:30 AM
68SCode4speed's Avatar
68SCode4speed
You can do the Granada front disc conversion if you are looking for something economical. Dennis gives discounts to members from this website.
http://www.discbrakeswap.com/body_index.html
James' website is chock-full of super helpful stuff too!
Old Mar 27, 2007 | 01:35 AM
67t5ponycoupe
You can try something like this too. It uses your stock spindles. http://www.mustangdepot.com/OnLineCa...brake_conv.htm An upgrade to a dual bowl master cylinder is a good idea too.
Old Mar 27, 2007 | 01:39 AM
Tony R's Avatar
Tony R
I do have the five lug
Old Mar 27, 2007 | 01:43 AM
67t5ponycoupe
Look at the bottom of the page to the link I sent you. All those kits work with V8 spindles. The Granada swap is cheaper but you will be scrounging parts for awhile. One of these kits will be bolted on and running in a day. It will depend if you want inexpensive or quick and easy.
Old Mar 27, 2007 | 01:48 AM
Tony R's Avatar
Tony R
I am not in too much of a hurry. I am almost done making myself a rotissery, so I am getting ready to remove the front and rear end to flip it over and take care of the undercarriage.
Old Mar 27, 2007 | 02:43 AM
umpmodracer20r's Avatar
umpmodracer20r
I just finished the Granada brake swap and they look great and stop way better than those drums. The pedal effort is so easy now andmy 67 coupe stops so much better now. Itwasn't to bad to find all of the parts if your up for it. There are many websites you can look at but if you want just send me a message with any questions concerning the swap.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
