Squeaky Suspension
Old Mar 29, 2007 | 02:38 AM
hardroxs19's Avatar
hardroxs19
Default Squeaky Suspension
I just had the suspension completely redone on my 67, and now the front suspention squeaks and creaks like crazy any suggestions, as to what might be causing this and how to fix it?
Old Mar 29, 2007 | 04:38 AM
2bav8's Avatar
2bav8
Default RE: Squeaky Suspension
You did greese up the zerk fittings right?
Old Mar 29, 2007 | 09:56 AM
Norm Peterson's Avatar
Norm Peterson
Original equipment bushings or poly?
Norm
Old Mar 29, 2007 | 10:11 AM
hardroxs19's Avatar
hardroxs19
Yes they were greased, they are O.E.M,
Old Mar 29, 2007 | 11:46 AM
kalli's Avatar
kalli
grease whatever you find in the front that only looks like a bit it could be moving.
You can spray WD40 and then test with pushing down the springs if it's gone or not.
That won't fix it for longer then a day, but it gives you a good indication on what is running dry.
same problem with every classic mustang
Kalli
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
