Windshield leaks
Old Mar 29, 2007 | 10:22 AM
magnumdd's Avatar
magnumdd
Default Windshield leaks
I have installed my windshield with a new weatherstrip and cannot get it to quit leaking water. I have a 1966 GT coupe. There are no glass people in my area that have worked on cars this old. Does anyone know what I can use to seal the windshield to stop the leaks?
Old Mar 29, 2007 | 10:26 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Windshield leaks
I've got the same problem, i was thinking about being the redneck that i am and putting a clear silicon coat of bathtub sealer around it, but someone here probably know what there doing more than me.
Old Mar 29, 2007 | 11:37 AM
andrewmp6's Avatar
andrewmp6
usmc is right clear silicon will work and besides the window trim will hide it
Old Mar 29, 2007 | 11:53 AM
USMCrebel's Avatar
USMCrebel
how do you get the window trim on and off with out bending it and going and having to spend an assload of money to have it done by "THE PRO"
Old Mar 29, 2007 | 12:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: USMCrebel
You need a special window molding removal tool.
http://cgi.ebay.com/ebaymotors/GM-Fo...ayphotohosting
Old Mar 29, 2007 | 12:23 PM
USMCrebel's Avatar
USMCrebel
ok, well im not good enough with things like that to attempt it so i would pay the pro.
Old Mar 29, 2007 | 01:41 PM
gothand's Avatar
gothand
Did you run a bead of silicon around the perimiter of the seal, glass meets the seal? After the windshield is in, you can then run a nice bead around the seam where the seal meets the body and it will be covered nicely by the stainless trim.
Old Mar 29, 2007 | 02:15 PM
sxs191's Avatar
sxs191
Don't bend (kink) the molding getting it off. For as little as the pieces seam, it's expensive to replace. Specially the back widow trim. Ask me how I know. [:@]
Old Mar 29, 2007 | 03:25 PM
USMCrebel's Avatar
USMCrebel
lol...how do you know? is it easy to put back on?
Old Mar 29, 2007 | 03:30 PM
dozierstang's Avatar
dozierstang
Get a pro to do it...that way if they tear it up or it still leaks then they will have to fix it. Make sure you get that in writing.
