Windshield leaks
Old Mar 29, 2007 | 04:13 PM
sxs191's Avatar
sxs191
Default RE: Windshield leaks
I just ripped off the old ones thinking it can't be that expensive to replace. Boy was I wrong. Back window trim alone was like $150.00. I haven't put them back on yet. I will pay someone to do that. I would really be pissed if I screwed up the new ones putting them on.
Old Mar 29, 2007 | 04:40 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
DAMN!!! yeah pro's are pros for a reason they can do their job better than me.
Old Mar 29, 2007 | 04:50 PM
MidNite27's Avatar
MidNite27
ORIGINAL: USMCrebel
If u do it once and get it right, ur now a professional.
Old Mar 29, 2007 | 08:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, the only difference from a novice and a professional, is that the professional gets paid for the job.
Old Mar 29, 2007 | 10:39 PM
shr's Avatar
shr
i would use urathane around the glass not bathroom caulk......most body shops and parts stores can get you it and it will be a million times better!
Old Mar 30, 2007 | 01:57 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Did you use any type of sealant? 3M makes a few good windshield adhesives. Check out here - it explains where to put the sealant.
Old Mar 30, 2007 | 02:24 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: shr
no you want to use a bedding and glazing type compound from 3m the urethane hardens up the bedding glazing doesnt
Old Mar 30, 2007 | 03:34 AM
az1966's Avatar
az1966
I went to some small used car lots and asked them who does their glass work some didn't want to talk unless I was buying... some did,,,got a guy to install my winsheild and rear back window seals ( I bought the parts) and he did it for 60 bucks,,,however am in the same perdicument asyou and will call the guy back,,,seemssome manufacturers are saying no need for sealant,,,well as we both know that's not the case,,,good thing I'm in AZ
Old Mar 30, 2007 | 04:39 AM
valley firearms's Avatar
valley firearms
I did both front and rear on my 68 last week. I used the 3M in a white tube like rmodel recommended. I really don't know if it works as everything is still frozen up here. One tube did both front and rear. I did the inside and outside. It had a consistency of roofing mastic. It looked like the black gooey stuff they seal flashings with. If it leaks I will oooz more in there I guess. As far as putting the trim on, it was easy. You have to be careful though. I used new clips and the trim popped right on. The only problem piece was the big piece on the bottom of the windshield. It's hard to push the trim toward the windshield so I used a mallot and a paint stick. Put the trim on as far as you can. Use the end of the paint stick on the front edge of the trim and tap it on. You have to lay the stick almost flat so you are actually driving the trim toward the back of the car and not downward. I used the paint stick so I wouldn't dent the stainless trim or harm the new paint.
[align=left] [/align]
Old Mar 30, 2007 | 02:14 PM
magnumdd's Avatar
magnumdd
Thanks for all the information. I have sealed the windshield with the 3M silicone. I am going to let it dry a few days before I water check it.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
