Engine Ground Location?
Old Mar 30, 2007 | 03:16 PM
crey's Avatar
crey
Default Engine Ground Location?
I'm in the process of reassembling a '66 Coupe with a 289 and automatic transmission.
Could you tell me where the ground wires to the engine attach? From the photos I've seen it looks like the stud for the coil on the front passenger side is a common ground, but the end of myalternator ground is too small for that. And where does the engine ground to the body?
Old Mar 30, 2007 | 04:48 PM
gothand's Avatar
gothand
Default RE: Engine Ground Location?
I've got my negative cable bolted to the lower right of the block. There is also a ground strap from the rear of the right head to a bolt on the body just above and to the side of the heater blower motor.
Old Mar 30, 2007 | 07:00 PM
68FastbackGT's Avatar
68FastbackGT
I thought the engine to chase ground came off the rear passenger side of the intake.
Old Mar 30, 2007 | 07:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
The battery ground hooks up right under the alternator. The other little ground strap is just to the right of the heater motor and hooks up to the rear of the engine.
[IMG]local://upfiles/10034/13251AEE522B4912B5EDD18D31F9601B.jpg[/IMG]
Old Mar 30, 2007 | 07:22 PM
mikethebike's Avatar
mikethebike
I made 2 ground cables from #2 welding cable by soldering solid copper 'I' type connectors and bolting them from the block to the chassis on each side of gthe engine. I then ran my negative battery cable to the block. 20 years and no ground troubles.
Nick Oliver
Oct 17, 2018 04:22 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
tmdm
Sep 4, 2015 06:45 PM
aleit2013
Sep 4, 2015 11:58 AM
cbird1177711
Sep 3, 2015 08:43 PM
