Alternator ?'s.
Old Apr 3, 2007 | 11:01 PM
badazz68stang's Avatar
badazz68stang
Default Alternator ?'s.
Has anyone ever installed a high power 1 wire alternator? Im thinkin bout gettin one from jegs or summit, cuz all the extra electronic loads im puttin on the stock alternator is gonna fry it, i know it.
Old Apr 4, 2007 | 12:15 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: Alternator ?'s.
Well, I can't say I have, but I did just have to replace the alternator in my truck, and I went with a real good one. I must say, I was shocked. I didn't know my windows rolled up that fast! And the lights in my dash were visible! It was awesome
Good luck though, I need to know this info too. I hear if you go to a 1 wire, you need to keep it above 2K rpm to keep it charging.
Old Apr 4, 2007 | 01:04 AM
boeing747arowair's Avatar
boeing747arowair
nop ive heard u jus hit the gas once and that initiates the charging but lets leave it to the pros lol.. any1?
Old Apr 4, 2007 | 01:13 AM
JamesW's Avatar
JamesW
You guys ever heard of Google.....?
http://www.powermastermotorsports.co...nators.html#15
Old Apr 4, 2007 | 02:12 AM
LCC's Avatar
LCC
I have a power master 100 AMP one wire, works great..
Old Apr 4, 2007 | 02:15 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
lincoln mark8 anf the taurus are great donors for a 130amp although its not a one wire setup but it can be had alot cheaper
Old Apr 4, 2007 | 09:33 AM
palerider's Avatar
palerider
I've got a powermaster 100amp also, I was kind of worried about needing the 2k rpm tokick it off. But you typically hit that just starting it and Ihve not had an issue with it - pretty easy install -powermaster has a built in regulator so you justhook wire to battery side of solenoid and good to go.Only down side is that you're gauge foramps is bypassed and won't give you a reading any longer.
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
ChampInSD
Oct 2, 2015 04:55 AM
MasterLanMan
Sep 26, 2015 10:03 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
