horrible SQUEAK
Old Apr 5, 2007 | 08:13 PM
6t9 stang's Avatar
6t9 stang
Default horrible SQUEAK
so we recently upgraded the brakes to Force 10 SSBC discs. for the first 3 or 4 weeks of driving the car, everything was fine. Now, however, there is a horrible squeak everytime i break. There are 2 possiblities that i can think of. 1) my dad did not seat the breaks, or 2) the proportioning valve is set wrong.
What do you guys think?
Old Apr 5, 2007 | 08:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: horrible SQUEAK
How do the rotors look? Are they grooved or smooth? They might just be squeaking. They make some gooey red , or maybe it's blue, but anyway you wipe that stuff on the back of the pad and it keeps the pad from squeaking when the brakes are applied.
Old Apr 5, 2007 | 08:27 PM
6t9 stang's Avatar
6t9 stang
what do you meanby grooved or smooth, like if there are wear marks on the rotors?
Old Apr 5, 2007 | 08:29 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Sometimes a small stone gets caught between the rotor and pad, causing chaos. As was said, look at the rotors. If they aren't smooth you have a problem. There should not be any grooves.
Old Apr 5, 2007 | 08:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 6t9 stang
Yeah, when the pads get old, the rotor will have grooves in it. I know your pads are not old, but just wanted to check with you to see if you have any wear on the rotors. That's why you need to turn the rotor when you put new pads on. Go to a parts store and ask for a pad lubricant. You put that on the metal side of the pad, and when you apply the brakes that metal part will not squeak. It has the consistency of axle grease.
Old Apr 5, 2007 | 08:59 PM
Hornblower's Avatar
Hornblower
I ♥ Acer
Soaring is correct. Believe it or not, brake systems need lubrication, but with special lubricants. Learn more here.
http://www.aa1car.com/library/2005/ic80560.htm
woodvette
Oct 30, 2015 01:14 PM
GLOCKer
Sep 28, 2015 07:36 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
TimeLord101
Sep 4, 2015 09:27 AM
Sandmanbjj
Aug 21, 2015 12:38 PM
