Tranny Slipping
Old Apr 7, 2007 | 04:40 PM
19stang66's Avatar
19stang66
Default Tranny Slipping
So I finally got to drive my Stang for the first time this year. I fixed a couple of tranny leaks and replaced the rear axle seals and put new rear end fluid in the differential.
Now my problem. When I shift into reverse or drive I have to rev the engine before the Tranny will engage into whatever gear i'm in. But once I'm up to speed it doesn't slip at all and runs just fine. I never had this problem last year before I stored her. So I'm thinking it has to be something I just did recently.
Could the new rear end fluid make it slip? I used the Royal Purple Synthetic stuff. Could have I screwed something up when I removed the axles and cracked the differential to drain the fluid? I really don't know whats wrong.
Old Apr 7, 2007 | 04:51 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Default RE: Tranny Slipping
Nah... The rear end fluid has nothing to do with the hesitation. That is steel on steel gearing.
Sounds like it is just taking a second to load it up. Stupid question. Did you check the tranny fluid level?
What does the fluid look like?
Old Apr 7, 2007 | 05:12 PM
65mojoe's Avatar
65mojoe
Ya double check your tranny fluid. If there is not enough in there it can feel like its not grabbing a gear. Since you just refilled I would suspect that before anything else. Since it can eventually grab a gear when you bring the rpm's up, you're probably short by maybe a quart.
Old Apr 7, 2007 | 05:46 PM
19stang66's Avatar
19stang66
Damn its cold out for April! 20* weather + Carbueration = no start. Found that out last night at 1am when leaving my friends house. Right after I posted this thread I thought to myself, "Did you ever put in more tranny fluid after you fixed those leaks? Nope you didn't dumbass." I added about 3/4 fluid and she drives perfect now! I even left a lil rubber at the top of the driveway! Pegleg burnouts FTL. I guess I was so excited to drive it last night that I forgot about the fluid level.
Old Apr 7, 2007 | 05:48 PM
65mojoe's Avatar
65mojoe
Hahaha, sometimes it seems like it can take forever for those c4's to fill up. I have a deep pan on mine it chugs fluid like beers. Glad to hear its smokin tires again.
EDIT: smokin tire...hahah you need to get a posi in that sucker[8D]
TCStangerv6
Oct 11, 2015 05:57 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
