electrical problem '66 any help???
Old Apr 7, 2007 | 07:16 PM
delkener's Avatar
delkener
Default electrical problem '66 any help???
i drive it everyday and i started it one day adn drove it for 15 min turned it off and the battery had nothing. i am thinking either alternator or somethign else if you have any ideas let me knwo thanks...
Old Apr 7, 2007 | 08:15 PM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: electrical problem '66 any help???
I would start by checking the simplest first. Clean and check the battery terminals for corrosion. The wellness of the battery would be next. Then theregulator and alternator. Goodluck.
Old Apr 8, 2007 | 06:55 AM
kalli's Avatar
kalli
when the engine is running, pull of the minus cable of the battery. if the car turns off, you have proof it's not charging.
Let us know what happens and we'll go from there
Old Apr 8, 2007 | 11:45 AM
boogerschnot's Avatar
boogerschnot
Listen to Kalli,, I had the same problem and ended up changing the alternator, voltage regulator, and then realized that my alternator wasnt hooked up exactly right.. But Kalli knows his stuff when it comes to electrical problems with mustangs..
Old Apr 8, 2007 | 11:53 AM
koesterca1's Avatar
koesterca1
Dont forget to check the actual battery cables.
Old Apr 8, 2007 | 05:15 PM
vinces65's Avatar
vinces65
if your burning out your head lights and your battery goes completely dead, then it's your voltage regulator that was my problem.
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
