heater box
Old Apr 9, 2007 | 12:19 PM
rustycoupe's Avatar
rustycoupe
Default heater box
Help!!. Whenever i've accelerated hard or revved the engine up high, antifreeze has been dumping out of the heaterbox. Yesterday it was very cold out and we tried to start her up and everything was steaming/smoking.
We had the hoses replaced awhile ago with lots of performance things and thought maybe they didnt connect the hoses very well.
It's leaking onto the passenger side toeboard.
Any ideas?
Thanks
Old Apr 9, 2007 | 12:29 PM
gmata's Avatar
gmata
Default RE: heater box
I used to have the same problem, there is a little radiator inside the heater box and mine was leaking, i disconnected the hoses and connected them directly into the engine without going into the heater box anymore.
Old Apr 9, 2007 | 01:58 PM
66GTKFB's Avatar
66GTKFB
Your heater core leaks. The 'hose jumper' works only if you believe in Global Warming.
Jim
Old Apr 9, 2007 | 02:08 PM
Timetravelinn's Avatar
Timetravelinn
you need to replace your heater core. I dont remember them being to expensive 30-40 bucks maybe.
Old Apr 9, 2007 | 03:13 PM
rustycoupe's Avatar
rustycoupe
difficult or no?
Old Apr 9, 2007 | 03:20 PM
gothand's Avatar
gothand
ORIGINAL: rustycoupe
difficult or no?
I don't know about the later models with the integrated AC, but the 65/66 heater core is a leisurelyone or twohour job if you're just changing out the core. I'd go ahead and install new seals and gaskets while I was in there.
Old Apr 9, 2007 | 08:47 PM
kalli's Avatar
kalli
yah what year is that car ?
you'll have it out pretty quick. Just disconnect the 2 hoses from firewall and then pull the core out of the heaterbox.
The replacement part is quite cheap.
see here:
http://store.cal-mustang.com/cm_able...19&CM_SA=0
I guess the others are roughly the same (mustangsunlimited, NPD ....)
if you have a radiator shop around the corner, they might be able to fix it for you.
Old Apr 9, 2007 | 11:38 PM
boeing747arowair's Avatar
boeing747arowair
farely simple install but yea you need a new core or eliminate it unless you need it.! i decided to get rid of the heater since in miami there is no need for it; therefore, i dont have to worry about interior leaks or what not!
Old Apr 10, 2007 | 05:31 PM
rustycoupe's Avatar
rustycoupe
Thanks for the help. Yea i ordered one for 32 after shipping from mustangsunlimited.com. its a 65 w/o ac. who needs it when its a vert. but i should be hoping to get it in on sunday...right now i just have several shop towels holding up the mess
Old Apr 10, 2007 | 05:54 PM
gmata's Avatar
gmata
ORIGINAL: 66GTKFB
Jim
Whats Wrong with the 'hose jumper' ??
