67 Fastback Transmissions
Old Apr 11, 2007 | 08:58 AM
Ant67's Avatar
Ant67
Default 67 Fastback Transmissions
Hey guyswith the 67 Mustang Fastback, what manual transmission did the fast back orginally comeout with as standard? am i right by saying it was a 4 speed? (i'm more after the transmission type (i.e. T-5, T - 45??)
Cheers
Anthony
Old Apr 11, 2007 | 01:14 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Default RE: 67 Fastback Transmissions
3 speed, not sure of the nomenclature for that one or the Toploader 4 speed
Old Apr 11, 2007 | 01:41 PM
66GTKFB's Avatar
66GTKFB
Ford used 6 different manual transmissions for 1967 of two different types, the 3.03 three speed and a 4 speed top loader. The only other designation used were for application, 6cy, 289 and 390- (3 speed) RAN-S, RAN-D, RAT-N and (4 speed) RUG- E, RUG-N, RUG-M. These were used on all models.
Jim
Old Apr 11, 2007 | 02:11 PM
easttennmotors's Avatar
easttennmotors
keep the toploader, 4 gears are better than 5...
Old Apr 11, 2007 | 05:52 PM
Ant67's Avatar
Ant67
ORIGINAL: 66GTKFB
Jim
Cheers jim, the box has been sitting in the workshop of around a year, and i have the task to strip it down and rebuild it, i also need to find a new shifter for this gearbox, it is the 4 speed toploader, but other then that i don't have its designation, do you know a company or shop i can get in contact with, bear in mind i'm in Australia, which probably makes the job alittle harder.
Thanks for the help mate
Anthony
Old Apr 11, 2007 | 06:02 PM
easttennmotors
just order a hurst shifter from summitracing.com or jegs.com you could probably go to your local parts shop and tell them you need a hurst shifter for a ford toploader and they can get you one...its around 290 american dollars...
Old Apr 11, 2007 | 06:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
As far as I know, David Kee is the best toploader guy in the United States. Contact him for information.
http://www.4speedtoploaders.com/shop/enter.html
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
