kick-down rod
Old Apr 7, 2007 | 09:32 PM
connor90's Avatar
connor90
Default kick-down rod
ok i just descovered that my kick-down rod isnt hooked up which would help explain the difficulty i have been having in breaking the tires loose . what does it hook to?
Old Apr 7, 2007 | 09:36 PM
66GTKFB's Avatar
66GTKFB
Default RE: kick-down rod
Everything but a transmission - which is where a kick-down rod goes.
Old Apr 7, 2007 | 09:44 PM
connor90's Avatar
connor90
lol sorry...i should have said where on the tranny does it hook to...my mistake
Old Apr 7, 2007 | 11:12 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
look where the sift linkage connects there should be an small lever arm that it hook to
Old Apr 7, 2007 | 11:36 PM
connor90's Avatar
connor90
ok i see where it is supposed to go but i guess im missing some kind of cable or something to connect the rod to the lever on the tranny.
Old Apr 7, 2007 | 11:53 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the rod should have a hole in the center with a plastic bushing and an e clip i believe
Old Apr 8, 2007 | 01:13 AM
6mustang6's Avatar
6mustang6
The kickdown doesn't have anything to do with you breaking your tires loose. It just shifts to a higher gear when the pedal is floored.
Old Apr 8, 2007 | 01:34 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: 6mustang6
The kickdown doesn't have anything to do with you breaking your tires loose. It just shifts to a lower gear when the pedal is floored.
fixed
Old Apr 8, 2007 | 01:56 AM
6mustang6's Avatar
6mustang6
Well.... damn. You got me. [:@] I did know that though.
Old Apr 8, 2007 | 03:43 AM
connor90's Avatar
connor90
lol it has everything to do with breaking my tires loose...lower gearing=tires smoking . like they would still squeal when i took off but not nearly as good as they do when im shifted into L...looks like once i get this fixed im going to be going through tires a lot faster
