chassis twisting?!!!!!!!!!
Old Apr 12, 2007 | 01:18 AM
stjs45's Avatar
stjs45
Default chassis twisting?!!!!!!!!!
I have a 66 with a pretty good 302. Im probably putting out 340hp. My 66 was a six cylinder to start with. I need to know if they have a uni-body. I mean is my frame one whole piece. Or will it twist once i put my 373 gears. Do i need to weld some kind of supports underneath the car?
Old Apr 12, 2007 | 01:27 AM
dcohen's Avatar
dcohen
Default RE: chassis twisting?!!!!!!!!!
all mustangs are uni bodies, the straight six's and the v-8s have the same body, if your worried about it i suggest a good set of subframe conectors, export brace, and a monte carlo bar, that will make your car plenty stiff
Old Apr 12, 2007 | 01:44 AM
JMD's Avatar
JMD
+1
Old Apr 12, 2007 | 04:09 AM
andrewmp6's Avatar
andrewmp6
my question is did you replace the springs and rear end the springs used in the 6 banger cars were weaker but if you do everything dconhen said it should be fine
mtgldr
Feb 3, 2024 09:00 PM
UrS4
Oct 3, 2015 06:23 AM
Sep 17, 2015 07:57 PM
MasterLanMan
21
Sep 16, 2015 03:26 PM
ccwebb
Aug 11, 2015 06:47 PM
