throttle tension
Old Apr 10, 2007 | 09:57 PM
eZ's Avatar
eZ
Default throttle tension
When i give the car some gas the throttle does not go all the way back to an idle it stays up a bit. I have to reach down and pull then gas pedal back out...would this mean my throttle link is too short or too long?
[/align]
Old Apr 10, 2007 | 10:00 PM
restomod66's Avatar
restomod66
Default RE: throttle tension
Kickdown Spring possibly could be worn!! Just a guess?????
Old Apr 10, 2007 | 10:05 PM
NorCalTroy's Avatar
NorCalTroy
I'm thinking throttle return spring. Check under the hood when it is "stuck" and see if it is hanging up on anything. If not, try a new throttle return spring.
Good luck!
Old Apr 10, 2007 | 10:06 PM
restomod66's Avatar
restomod66
That is what I meant but got the two springs mixed up!!!
Old Apr 10, 2007 | 10:16 PM
eZ's Avatar
eZ
yea its a brand new spring...the double over kind that came with my edelbrock...maybe i need a stronger one.
[/align]
Old Apr 10, 2007 | 11:12 PM
mat11089's Avatar
mat11089
Sometimes on the double springs when u stomp on it the inner spring and outer get caught together causing it to stick.Mine used to do the same thing so i took off the outside one.
Old Apr 11, 2007 | 02:10 AM
Guitylerham's Avatar
Guitylerham
I had the same problem, mine would stick slightly but only when the engine was running. Otherwise it would return to correct position. I finally just put two springs on to force the throttle shut. I can post a pic tomorrow if you want.
Old Apr 12, 2007 | 01:38 AM
eZ's Avatar
eZ
yea please post when you get a chance
[/align]
Old Apr 12, 2007 | 04:39 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
check for improper linkage setup the po had mine in the wrong spot so it felt like crap
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
MacSerio
Sep 27, 2015 01:05 PM
col2560
Sep 25, 2015 06:51 AM
JDWalton
Sep 24, 2015 08:47 PM
