Welding help
Old Apr 14, 2007 | 05:00 PM
green_blurr's Avatar
green_blurr
Default Welding help
I cant seem to get my plug welds to hold i am trying to weld my new fender aprons on to the frame. At first i thought it was the weld through primer so i sanded it off. Still nothing i will fill the plug hole with my mig welder and i will wait then pop ! the weld come right off the frame WTF is wrong?
Old Apr 14, 2007 | 05:45 PM
green_blurr
Default RE: Welding help
Any help would be much appreaciated
Old Apr 14, 2007 | 07:27 PM
jaw66's Avatar
jaw66
Are you using gas or flux core? Make sure the gas is on. Make sure you have the heat up high enough and the wire speed adjusted right 3 - 4 setting for both and work from there. You should wind up with a nice circle on the back side that will tell you there is good penetration. Start there and see how it goes. Jason
Old Apr 14, 2007 | 08:18 PM
66GTKFB's Avatar
66GTKFB
Practice your welding on some scrap metalwith higher current, aka heat like jaw66 said, until you get it right.
Jim
Old Apr 14, 2007 | 08:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, quit fuggin around practicing on the fender well. Get some old computer covers and practice on them. If you are burning holes and not welding, then the heat is too high. Not welding or unable to strike a spark, then heat is too low. Get the gas ane wirefeed set right and practice, practice, practice.
Old Apr 14, 2007 | 08:32 PM
66GTKFB's Avatar
66GTKFB
How do you get to Carnegie Hall? Practice man, practice.
drfister
May 3, 2018 10:38 PM
cyclop5
Oct 3, 2015 09:21 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 17, 2015 07:57 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
