i hear you knocking....
Old Apr 15, 2007 | 01:59 PM
jimbob's Avatar
jimbob
Default i hear you knocking....
and not sure what it is.
got a 66 200ci. quiet when cold, as it warms up get a knock in the back of the engine.
then eventually it goes away.
disconnected the plug, no effect.
got the stethoscope, definitely on the bottom back of engine, not transmission.
Any ideas? things to try and check ?
Thanks in advance
Old Apr 15, 2007 | 02:06 PM
mustanglover66's Avatar
mustanglover66
Default RE: i hear you knocking....
worn connecting rod would be my guess
Old Apr 15, 2007 | 02:11 PM
Scott H.'s Avatar
Scott H.
Old Apr 15, 2007 | 03:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: mustanglover66
I don't think so. A rod bearing would knock all the time. The starved for oil lifter makes more sense.
Old Apr 15, 2007 | 05:55 PM
ponyx2's Avatar
ponyx2
Rod bearings usually knock on deceleration, my guess is a main bearing.
Old Apr 15, 2007 | 07:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
I had a rod bearing knocking in my 51 Chevy and that sucker knocked all the time. Louder on decelleration, but also on acceleration. I drove it from El Paso to Alpine at 50 mph with it knocking all the way. I was afraid to push it any faster for fear of throwing the rod. I thought I would never get there. I sold that car for $20.00
Old Apr 15, 2007 | 08:33 PM
Bulldog66's Avatar
Bulldog66
Little confused here. It is audible at operating tempature and then goes away? Starving lifters would happen at start up and cold temps. Noise at operating temp and then dissapear is not making much sense.
Does this happen at all rpm's? ( Assuming you're under the hood and listening, this ruleing out drive train ).
Old Apr 15, 2007 | 08:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
You need to get a stethoscope or at least a long handled screw driver and try to locate exactly where it is coming from. Obvioulsly some bearing is not getting enough oil at times. Back in the old days we would run some diesel through the engine to clean out any stoppage that may be in the channels.
jerrytubes
Oct 23, 2015 12:11 PM
breaking
Oct 2, 2015 01:27 PM
Shadow7874
Sep 24, 2015 09:06 PM
schecterplayer
Sep 23, 2015 08:38 AM
