How Safe
Old Apr 17, 2007 | 02:42 PM
Lumbergh's Avatar
Lumbergh
Default RE: How Safe
I like the manual steering in my truck, but you do need to convert from power steering to true manual steering. You need to have the mechanical advantage built into a manual steering system if you want to have a usable steering system.
Old Apr 17, 2007 | 03:49 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ok well i just wanted to know cause i don't have time to fix it now so i have been driving with it llike it is now but i am babying it cause i don't wanna break anything
Old Apr 17, 2007 | 09:29 PM
mikethebike's Avatar
mikethebike
ORIGINAL: gothand
My advice is that if you truly want the manual steering, replace your steering with the stock manual stuff and sell your power stuff on Ebay for probably $500+. IIRC, the power steering gearbox is the close ratio which makes it harder to turn than the wide ratio, non-GT manual steering.
FWIW, my '65 GT had the close ratio manual steering and it was a real bear. It was driveable, of course, but it did get a bit fatiguing at times.
I had the Shelby steering arms + a 1967 power steering from a 390 + a 14" wheel and 215/60-15 Comp T/A's. Worked perfect at 100 mph but you could not parallel park the damn thing!!
guitarman376
Sep 30, 2015 05:54 PM
ikeatech
Sep 16, 2015 01:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
v8sn95
Sep 7, 2015 10:17 AM
