Tranny lines....
Old Apr 16, 2007 | 07:21 PM
mat11089's Avatar
mat11089
Default Tranny lines....
66 v8 (600 holley)with c4.On the cooler lines which one goes where on the tranny. And could this cause it to shift into 3rd only occasionally.Also,I only do around town driving and i went from 13mpg to 7.5 this could obviously be because of no 3rd gear right?Just trying to get any issues ironed out before i decide to take a loan from pops. Theres plenty of fluid and have adjusted bands however there are some good sized leaks from the shifter lever and adjusting screws.
Old Apr 16, 2007 | 07:39 PM
66GTKFB's Avatar
66GTKFB
Default RE: Tranny lines....
Both the out and in for transmission lines are on the right side. The one in front is the outlet and normally goes to the right hand fitting on the radiator, the rear fitting is the inlet from the left side of the radiator, but it does not make a difference if they are backwards. There is a special right angle fitting on the rear (inlet). I got one from a local Mustang shop that the owner said was not machined correctly, it was not drilled all the way thru. He said it was not the only one that he had seen so check the flow, disconnect and look. However, cooling would not cause a loss of third gear. I recomend you go to a shop.
Jim
Old Apr 16, 2007 | 07:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
Your cooling lines have nothing to do with it not shifting. Check your fluid, then try adjusting the bands. There is an article on how to do that in the FAQ under transmissions.
Old Apr 16, 2007 | 11:01 PM
mat11089's Avatar
mat11089
alright thanks.ya i already did the fluid and bands thing so shes going to the shop tom for 70's c4 and shift kit.Now itll match the brand new 302 at least.
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
